Blinking / Flashing in overview
  • Beam
    • May 2007
    • 12
    Whats the meaning of the blinking in the overview? It seems to be a pending state. But the whole line is flashing.
  • Alexei
    Founder, CEO
    • Sep 2004
    • 5654
    If you're using 1.4.x, click on a questionmark in the screen for explanation.
    Alexei Vladishev
    New York | Tokyo | Riga
    My Twitter
    • dreas
      • Aug 2007
      • 89
      This just means that the data recently changed .. probably cause you just setup Zabbix? Check again after an hour or so and they should have stopped flashing (assuming there was no recent change).
      • bbrendon
        • Sep 2005
        • 873
        I haven't read the manual on this but my guess is ...
        If they are blinking, zabbix doesn't know if they are red or green and is waiting a bit to initialzie and then make a final determination.
        Unofficial Zabbix Expert
        Blog, Corporate Site
        • Beam
          • May 2007
          • 12
          Yes, they stop blinking after a while. But why the whole line is blinking, when only one trigger has changed? That confused me a bit.
