Zabbix on RHEL 5
  • charles cross
    • Sep 2007
    • 27
    Zabbix on RHEL 5
    Hello! I need to install Zabbix 1.4.2 on Red Hat Enterprise 5 legal copy. I want to now if I'm going to be on trouble on installation, and wich versions of mysql and php are the best for this.
    Thank you
  • SharkCZ
    • Apr 2006
    • 39
    Get the EPEL repo from http://fedoraproject.org/wiki/EPEL/FAQ#howtouse
    and then "yum --enablerepo=epel-testing install zabbix zabbix-agent zabbix-web". It will install Zabbix plus all packages that are required for Zabbix to run.
    • charles cross
      • Sep 2007
      • 27
      3 dependences not found
      Hello! I did it, but it could'nt resolve 3 dependences, php-gd, php-mysql and another one I can't remember... If I get them for myself, I found new dependences, so it is a hard and tedious work. Would you help me another time?
      • SharkCZ
        • Apr 2006
        • 39
        Strange, these packages are built from main php source package. What kind of RHEL 5 do you have?
        • charles cross
          • Sep 2007
          • 27
          Version Server
          Thank you!
          I could make installation in a Computer with license, just doing what you told me, I supose it gets the 3 rpm's from the red hat repos, but I'm trying to make another install into a Virtual machine with no license for devoloping and testing, and here is where I have the problems.
          The third rpm it can't get is php-bcmath.
          My version is RHEL 5 server (NOT 64), if I try to get the dependences for myself I can't install some rpm's because they are asking me some dependences that I allready have!!!
          If you need more info please tell me.
          • SharkCZ
            • Apr 2006
            • 39
            It is clear now :-) I would suggest to do the development on CentOS 5 which should be binary compatible with RHEL 5. Then yum will resolve all the depencies (it is possible that the php-gd, -mysql and -bcmath will require other packages to be downloaded). Or you can use rpms from CentOS and install them in Redhat.
            • swaterhouse
              • Apr 2006
              • 268
              You can also follow the steps I wrote for CentOS (which is about 99.8% the same as RHEL)
              http://www.zabbix.com/wiki/doku.php?...:centosinstall
              • charles cross
                • Sep 2007
                • 27
                So, wich version?
                Thank you another time, your help is lighting my way!
                OK, I will try with CentOS, I'm just downloading CentOS 5.0, but is this equal to RHEL5 server?? There is a server version of CentOS 5?? Do you think I'll have problems if I devolope on CentOS and I put zabbix devoloped after into RHEL 5?
                Excuse me, I'm asking too much!!!
                • SharkCZ
                  • Apr 2006
                  • 39
                  CentOS is a superset of all RHEL "versions". And I don't think there could be a problem with the transfer CentOS x -> RHEL x.
                  • charles cross
                    • Sep 2007
                    • 27
                    Epel for CentOS?
                    So, wich epel repository need I for CentOS 5?? Samer as RHEL5 ? Or should I look for another repos?? If I do the same with yum that I did with RHEL 5 I will get Zabbix installed?? I mean this:
                    • SharkCZ
                      • Apr 2006
                      • 39
                      Yes, the same as for CentOS 5, the command is also the same.
                      • swaterhouse
                        • Apr 2006
                        • 268
                        You dont have to install CentOS to follow the directions, just follow the steps for installing zabbix starting with the "Installation Prerequisites". Anytime you see CentOS 5 you can substitute RHEL 5. I havent tested it on RHEL but it should work step for step as they are 99% the same.
                        • Alexei
                          Founder, CEO
                          • Sep 2004
                          • 5654
                          FYI We have CentOS 5 in our compile farm for regression and automated build. I wouldn't expect any buuild problems on this platform.
                          Alexei Vladishev
                          New York | Tokyo | Riga
                          My Twitter
                          • Mosquito
                            • Sep 2007
                            Just a quick question, when I do
                            yum info zabbix zabbix-agent zabbix-web
                            I am pulling back info for only 1.4.1. Is 1.4.2 in the repo yet?
                            EDIT:
                            Nevermind, I was missing the "--enablerepo=epel-testing". It is in the testing EPEL repository.
                            • charles cross
                              • Sep 2007
                              • 27
                              #15
                              Done!
                              I could do it on CentOS 5 following swaterhouse, but I can't make it on RHEL 5 doing the same because I could'nt install centOS repos,now it's working!!!
                              Thank you everyone!!! See you later!
