IBM SAN Switch / DS4700 Storage
  • thiago.info
    • Feb 2008
    • 28
    Does anyone have an example on how to monitor an IBM SAN Switch and/or an IBM DS4700 Storage System? I've found an SNMP documentation about the Brocade SAN switch, but there are lots of OID'ś and I don't know where to get an useful thing information there.
    Thiago
  • luquee
    • Apr 2008
    • 13
    Monitoring IBM SAN Switch / DS4700 Storage
    are you setup these monitoring for IBM DS4700 now ?
    • jlares
      • Jun 2008
      Hi, I´m monitoring an IBM FC Switch Brocade 8 ports with these OIDs:
      1. To get the total number of FC ports in the brocade switch
      snmpwalk -v 1 -c public 1.0.0.117 .1.3.6.1.4.1.1588.2.1.1.1.6.1.0
      Response: SNMPv2-SMI::enterprises.1588.2.1.1.1.6.1.0 = INTEGER: 8
      2. To verify that the FC port is active (5)
      Legend:
      # # status results:
      # O unknown (only for operationnal)
      # 1 online
      # 2 offline
      # 3 testing
      # 4 faulty
      snmpwalk -v 1 -c public 1.0.0.117 .1.3.6.1.4.1.1588.2.1.1.1.6.2.1.5.$Port
      Response: SNMPv2-SMI::enterprises.1588.2.1.1.1.6.2.1.5.1 = INTEGER: 2
      3. To verify Physical state of the FC port (9)
      Legend:
      # 1 "and Physical state is noCard"
      # 2 "and Physical state is noTransceiver"
      # 3 "and Physical state is LaserFault"
      # 4 "and Physical state is noLight"
      # 5 "and Physical state is noSync
      # 6 "and Physical state is inSync"
      # 7 "and Physical state is portFault"
      # 8 "and Physical state is diagFault"
      # 9 "and and Physical state is lockRef"
      snmpwalk -v 1 -c public 1.0.0.117 .1.3.6.1.4.1.1588.2.1.1.1.6.2.1.3.$Port
      SNMPv2-SMI::enterprises.1588.2.1.1.1.6.2.1.3.1 = INTEGER: 4
      With this information you can create the template for your switch and create also some triggers.
      I´m looking to monitor also the speed of every port, when I find it I will post it.
      Sorry for my english.
      Hope this help!.
      • bizonek
        • Oct 2009
        Hi, I have IBM Brocade 16B2.
