nodata trigger
  • xs-
    • Dec 2007
    • 393
    nodata trigger
    First of all, the nodata trigger is great, really, but it has one downside.
    When a zabbix_server has been down for more than the nodata(<time>) all triggers, and related action, fire and our server sends out tons of email and sms alerts . . . which kinda sucks.
    The reason for this is that this trigger works independantly of the actual received data. It just compares the timestamp of the last received item value, not the value.
    So my question is; does anyone now of a way (or is using a method) to not have the nodata triggers fire on zabbix_server start for at least 1x or 2x the poll interval of the item its for?
    (or another way to prevent the nodata triggers from going off at the wrong time).
  • bbrendon
    • Sep 2005
    • 873
    I just manually disable all actions.
    You could add a mysql command to your init script to do this for you automatically as well. I've thought about doing this, but haven't...
    Unofficial Zabbix Expert
    Blog, Corporate Site
    • Alexei
      Founder, CEO
      • Sep 2004
      • 5654
      The nodata triggers are not supposed to be activated after ZABBIX server restart, at least in 1.4.4 and later releases. Otherwise it is a bug.
      Alexei Vladishev
      New York | Tokyo | Riga
      My Twitter
      • xs-
        • Dec 2007
        • 393
        For example, the following will cause actions to be sent when i stop the zabbix server for 600+ secs and start it again:
        ({template:agent.ping.last(0)}#1)|({template:agent .ping.nodata(600)}=1)
        the item is an active check.
        • bbrendon
          • Sep 2005
          • 873
          Then I'm not sure. I'm so use to disabling them, its automatic. I don't want 100 txt messages when I start the server.
          ...I'll wait for someone else to test this. I'm not brave enough.
