Zabbix installation in FC3
  • raghaven.kumar
    • Mar 2008
    • 34
    I am having FC3 in a client and i need to install zabbix-agent in it.
    I am not supposed to compile packages on that machine.
    And I dont know how to use the precompiled packages???
    Or else is there any rpm file for zabbix-agent for FC3??
    PS:Have installed zabbix-server in a Ubuntu server and its running.
  • raghaven.kumar
    • Mar 2008
    • 34
    No Reply???
    • raghaven.kumar
      • Mar 2008
      • 34
      I tried by installing FC6 rpms, phew!!
      Too many dependencies!!
      Can anyone tell me is there a way to install zabbix without compiling for FC3??
      • raghaven.kumar
        • Mar 2008
        • 34
        Thanks for your reply guys,
        I compiled the package on the machine
        by convincing my superiors that there is no other way to install in FC3
        and telling them that Zabbix is ineed a great application.
        • bbrendon
          • Sep 2005
          • 873
          You also could have gotten access to another fc3 machine and compiled it there. i'm not sure what libs fc3 uses.
          I would probably dump an fc3 machine. isn't that thing like 5 years old?
          Unofficial Zabbix Expert
          Blog, Corporate Site
          • raghaven.kumar
            • Mar 2008
            • 34
            hi dude,
            theres only one machine havin that fc3
            so no other go.
            btw, you are right, its indeed an old one.
            but they are our clients machine.
            So, no complaining
            • just2blue4u
              • Apr 2006
              • 347
              I compiled nearly all of our clients by myself.
              On RedHat9, FC1/2/3/4/5/6 and CentOS5.0.
              On some REALLY old Machines running RH9 and not having some needed applications (e.g. compiler) i just copied the compiled zabbix binaries from a similar system, even that worked for me!
              Big ZABBIX is watching you!
              (... and my 48 hosts, 4513 items, 1280 triggers via zabbix v1.6 on CentOS 5.0)
