Local agentd not responding on 1.4.5 running on CentOS 5.1
  • Jason
    • Nov 2007
    • 431
    I've a zabbix server up and running, and it seems to be monitoring remote agents perfectly happily.
    However, the agentd on the zabbix server itself doesn't seem to be responding. I've tried both the agent I compiled and the pre-compiled one and when I try
    zabbix_get -s 192.168.124.25 -k agent.version
    I get
    zabbix_get [21812]: Timeout while executing operation.
    In zabbix itself the error reported on the hosts page is ZBX_TCP_READ() failed [Interrupted system call]
    I've set up the host to connect by its IP address and have tried defining both 127.0.0.1 and the machines IP address (192.168.124.25) with no luck.
    Any ideas?
    zabbix_agentd.conf
    # This is config file for zabbix_agentd
    # To get more information about ZABBIX, go http://www.zabbix.com
    # List of comma delimited IP addresses (or hostnames) of ZABBIX servers.
    # No spaces allowed. First entry is used for sending active checks.
    # Note that hostnames must resolve hostname->IP address and
    # IP address->hostname.
    Server=192.168.124.25
    # Server port for sending active checks
    ServerPort=10051
    # Unique hostname. Required for active checks.
    Hostname=zabbix
    # Listen port. Default is 10050
    ListenPort=10050
    # IP address to bind agent
    # If missing, bind to all available IPs
    ListenIP=192.168.124.25
    # Number of pre-forked instances of zabbix_agentd.
    # Default value is 5
    # This parameter must be between 1 and 16
    StartAgents=2
    # How often refresh list of active checks. 2 minutes by default.
    #RefreshActiveChecks=120
    # Disable active checks. The agent will work in passive mode listening server.
    #DisableActive=1
    # Enable remote commands for ZABBIX agent. By default remote commands disabled.
    #EnableRemoteCommands=1
    # Specifies debug level
    # 0 - debug is not created
    # 1 - critical information
    # 2 - error information
    # 3 - warnings (default)
    # 4 - for debugging (produces lots of information)
    DebugLevel=4
    # Name of PID file
    PidFile=/var/tmp/zabbix_agentd.pid
    # Name of log file.
    # If not set, syslog will be used
    LogFile=/tmp/zabbix_agentd.log
    # Maximum size of log file in MB. Set to 0 to disable automatic log rotation.
    #LogFileSize=1
    # Spend no more than Timeout seconds on processing
    # Must be between 1 and 30
    Timeout=20
    # Format: UserParameter=<key>,<shell command>
    # Note that shell command must not return empty string or EOL only
    #UserParameter=system.test,who|wc -l
    ### Set of parameter for monitoring MySQL server (v3.23.42 and later)
    ### Change -u<username> and add -p<password> if required
    #UserParameter=mysql.ping,mysqladmin -uroot ping|grep alive|wc -l
    #UserParameter=mysql.uptime,mysqladmin -uroot status|cut -f2 -d":"|cut -f1 -d"T"
    #UserParameter=mysql.threads,mysqladmin -uroot status|cut -f3 -d":"|cut -f1 -d"Q"
    #UserParameter=mysql.questions,mysqladmin -uroot status|cut -f4 -d":"|cut -f1 -d"S"
    #UserParameter=mysql.slowqueries,mysqladmin -uroot status|cut -f5 -d":"|cut -f1 -d"O"
    #UserParameter=mysql.qps,mysqladmin -uroot status|cut -f9 -d":"
    #UserParameter=mysql.version,mysql -V
  • raghaven.kumar
    • Mar 2008
    • 34
    Comment the ListenIP parameter
    and restart agent.
    That should work
    • Jason
      • Nov 2007
      • 431
      I've tried that and restarted both agentd and server...
      No joy
      • Jason
        • Nov 2007
        • 431
        Hmmm... I then put it back into passive mode (DisableActive=1) and then it suddenly started sending back data
