Google Talk Notification
  • Filter
    Its possible to receive jabber notification through at Google Talk?
    Yes.
    What is your problem?
      how can I do configuration?
      In media types in Jabber Identifier MY_EMAIL, and password MY_PASSWORD?
      In users, I add Media, Jabber, MY_EMAIL?
      regards,
      Samuel Rios Carvalho
      [email protected]
      [email protected]
        Oh, sorry. Zabbix 1.4.5 does not allows to configure additional parameters (ssl, port numbers, etc), so it might be required to modify source code.
        BTW, Gmail is not very different from other Jabber servers:
        http://www.google.com/support/talk/b....py?topic=1415
          Alternatively you could also use an external script to do the jabber stuff. I have a PHP shellscript which does this for me in my setup. It allows some more configuration.
            Has this changed? If not, im new to Jabber. What is the best Jabber client recommended for:
            Windows
            Linux
            And Windows Mobile (phone)
            Also, should i sign up for a jabber service with Google? Or is there anymore reliable?
              I found trillian and the astra project. It looks good. Will it work?
                As long as they are compatible with the XMPP protocol, they should work just fine. And no, nothing should have changed since the other posts in the thread were written.
                  Im not sure if they are. Since I think my Zabbix is not configured with Jabber i can test it. Actually not even emails alerts are send. But this Trillian looks good it i make it work.
