Call for discussion on ZABBIX 1.8
  • miguelangelopereira
    • Feb 2009
    Suport for Nagios scripts...(nagiosExchange)...
    Templates for other devices/systems...
    Active Directory
    Oracle
    Exchange
    • lostmarbles
      • Mar 2009
      • 50
      #137
      Trend Prediction
      See this discussion on trend prediction and NMS:
      http://www.thecepblog.com/2009/03/04...oring-systems/
      • sege
        • Jan 2008
        • 40
        #138
        Stability stability and stability. We just can't have releases leaking memory like 1.6.2. In 24 hours it has eaten up 3GB RAM. I have to restart it every day. this isn't good.
        More focus on bugs than new features at the moment.
        If I could wish for features it's a more complex user rights system. I'd like to be able to give my customers a view of just their port in a switch. Now I can give them nothing or the entire switch.
        • Alexei
          Founder, CEO
          • Sep 2004
          • 5654
          #139
          Bug fixing IS our primary focus currently!
          Alexei Vladishev
          New York | Tokyo | Riga
          My Twitter
          • nelsonab
            • Sep 2006
            • 1233
            #140
            I think his point might have been more about making a bug fix and then making it available for the current version. Perhaps it would be useful to make a patchset available for existing bugs for the version or versions the bug was reported for. You don't need to change the release version, but if you need the bugfix you can use it now and not have to wait for the next release, you (the end user) just have to do the work yourself.
            RHCE, author of zbxapi
            • richlv
              • Oct 2005
              • 3112
              #141
              that's more or less possible already through the svn.
              i've had patches applied through the automated upgrade procedure before.
              to play the guessing game, i'd guess he meant less bugs slipping through to the releases
              (there we go again, showing that a single thread for such a discussion isn't feasible =) )
              • sege
                • Jan 2008
                • 40
                #142
                My problem is the highly unstable releases. I really don't care about svn versions and patches flying around. I'm in need of a product which is stable when running the latest stable release. Hunt down bugs and release a stable versions.
                • kens
                  • Oct 2006
                  • 27
                  #143
                  Vpn/tls/ssh
                  I use Zabbbix to monitor several hosts at remote sites over the Internet, and plan to extend this type of usage.
                  Although the data isn't really that sensitive, who cares that / is 85% full, but the command sessions could be abused.
                  I've seen discussion on the forum about using TLS to secure these connections and others who use VPN's/stunnel in these situations.
                  What would be really good would be enhancing the protocol to allow a Zabbix server to initiate a passwordless SSH session with certificates to a client system.
                  This is a high priority in my environment.
                  Ken
                  • areplogle
                    • Oct 2007
                    • 16
                    #144
                    Possible Solution for Report Generation?
                    I would love to see two things:
                    1.) a few standard reports that can be generated about availability that are more extensive then the current system in 1.6.x that have graphs and overall better ability for layout that are presentable and exportable in pdf format etc.
                    2.) ad-hoc report generation similar to what jasper and pentaho do. This one is a *LOT* more complex and more effort involved I know.
                    Thanks,
                    Andrew
                    • lostmarbles
                      • Mar 2009
                      • 50
                      #145
                      Please Print GMT on All Charts in the Future!
                      Can you please put the timezone, in GMT, on all charts in the future?
                      Now the charts have a time scale with no reference.
                      Thanks!
                      • NOB
                        • Mar 2007
                        • 469
                        #146
                        Active Directory
                        Oracle
                        Exchange
                        Support for Nagios plugins is already available in 1.4.x
                        Just use a very small (almost) generic wrapper script:
                        check_dns nagios-plugin-parameter1 nagios-plugin-parameter2 ... > /dev/null 2>&1
                        echo $?
                        That's it.
                        HTH,
                        Norbert.
                        • Cray
                          • Mar 2009
                          • 72
                          #147
                          Hi all
                          Don't know if this has been discussed yet, but I would love to see a patch tracking system in Zabbix
                          e.g :
                          - a patch has been released regarding the memory leak in Zabbix 1.6.2
                          - a patch has been release regarding crash xxxx, consider upgrading
                          etc.
                          • mjs
                            • Mar 2009
                            Log scale
                            I would like to request that we be able to set up the y-axis on graphs with a log scale. Many of my checks are based on response time which is generally under a 100ms, but there are times when the response is 1 or 2 seconds. This leaves me to deal with either points being plotted off of the graph or making the y axis span a large range and not be able to see the points well since most are close to 0.
                            • hubertf
                              • Jun 2007
                              Please add calculated item support
                              Since at least 2007 many people have asked this feature...
                              ex :
                              For example i just want to graph the used memory... today noway to have an item like this : vm.memory.size[total]-vm.memory.size[available]
                              Now, we can just do math... on triggers... the only math permitted on an item is a multiplier...
                              There's many example where you want to have an item calculated...
                              please add such functionnality and i will convert my IT to zabbix!
                              • julius
                                • Nov 2008
                                flap detection
                                It would be nice to see something like flap detection in Nagios.
                                Sometimes i get hundreds of messages in an hour because some of servers or swiched begins to flap
