Web Frontend improvement. "All" as default page filter
  • stan.vasiljev
    • Jan 2008
    • 28
    Good time of day.
    Page filter (items in "Group" and "Host" comboboxes) has default value "All". Its acceptable when you load page in first time. After that page filter will load previous selected choice (saved in DB).
    If you have a few distributed nodes - page can remember group/host from distributed node you selected in the Zabbix frontend. This group/host will be invalid for another selected node, so in next time when you load page (for example "Items") for another node - it will reset Group/Host selection to default value "All" and load a total amount of items. It can take a long time and a lot of system resources for web-browser.
    Please, change default filter from "All" to the first group and host in combobox list.
    And add individual save of page filter for distinct selected nodes to the user web-profile, please.
    Thank you for your work. Good luck!
  • NOB
    • Mar 2007
    • 469
    Hi stan.vasiljev
    I second this proposal !
    It's a PITA that all is the default preselection for all nodes in
    the item and trigger pages.
    The last setting is not remembered after switching the
    view to a different node.
    Update: And by switching from Configuration to Monitoring/Latest data and vc. vs. the
    setting of the host is lost, too. And all data of all hosts are shown
    Another update: And by selecting trigger depencies all triggers of all hosts and templates are shown
    BTW: "Paging" is no real fix.
    Thanks in advance to the developers for fixing this.
    Best regards
    Norbert.
    • Aly
      ZABBIX developer
      • May 2007
      • 1126
      May be this one will help: Adminsitration->general->GUI->Dropdown first entry = none;
      Zabbix | ex GUI developer
      • NOB
        • Mar 2007
        • 469
        Hi Aly
        thanks for the tip, but: we are running 1.6
        Best regards
        Norbert.
        • stan.vasiljev
          • Jan 2008
          • 28
          Thanks for answers. I'm glad to know about this feature in 1.8. New front-end must be much better than 1.6 series.
          • exkg
            • Mar 2007
            • 718
            My two cents ...
            In 'include/defines.inc.php':
            define('ZBX_DROPDOWN_FIRST_ENTRY', 2); // 0 - NONE, 1 - ALL, 2 - SIMILAR ZBX 1.6.2 (compatibility mode)
            define('ZBX_DROPDOWN_FIRST_REMEMBER', 1); // 0 - do NOT remember, 1 - do remember
            []s,
            Luciano
            Luciano Alves
            www.zabbix.com
            Brazil | México | Argentina | Colômbia | Chile
            Zabbix Performance Tuning
            • stan.vasiljev
              • Jan 2008
              • 28
              it works!
              Thanks, Luciano, your info is helpful for my situation (Zbx 1.6.7 with a few nodes).
              Frontend will not load "All" items after node change, if we set variable in 'include/defines.inc.php' to 0:
              define('ZBX_DROPDOWN_FIRST_ENTRY', 0); // 0 - NONE
              • NOB
                • Mar 2007
                • 469
                Hi Luciano
                thanks for your tip.
                One big disadvantage though:
                If you select NONE like stan.vasiljev did: you can no longer select ALL to view, e.g., all active triggers.
                This is not useful for monitoring purposes !
                Best regards and happy new year
                Norbert.
