SNMP Builder for Zabbix
Thanks. Its works fine.Fobius,
here is my full zabbix frontend directory
http://wikisend.com/download/585042/zabbix22.tar.gzComment
Johansen,
here is my screen.
(sorry, but I pasted it as attachment, don't know how to paste as image)
Try use host ip or FQDN, not only hostname.
And there is must be OID tree.
I can't see this on your screeenLast edited by KorJek; 18-03-2014, 10:04.Comment
Thanks for your fast response.
Well, I updated zabbix to 2.2.2 (was still on 2.2.1) and copied your frontend files. Now I can expand the OID tree but still receive the same error.
maybe I don't understand the whole process right, but generally the scope of that extension is that you can choose an empty template, choose an existing MIB (or upload a new one) and point to a new host. then snmp builder will write all discovered items and values to the template and link it accordingly.
is that correct?
PS: also tried with fqdn and ip address, same errorLast edited by johansen; 18-03-2014, 10:40.Comment
Yes and no.Thanks for your fast response.
is that correct?
My understanding is that this extension build OID tree.
Than you manually go through this OID tree (in the left) and if you find needed OID, then you click on the right and add this OID to the template.
admit, than some OID could not return value (No Such Object available on this agent at this OID).
Manually intervention also needed, because you could not select graph color through snmpbuider (for example).
Thats my understanding, though I could be wrong.
With error. Try look in /etc/resolv.conf and /var/log/httpd/httpd-error.logComment
Hi all,
snmp builder is driving me crazy
I did not understand how this feature works!
I'm using zabbix 2.2 on Cent OS 6.5 server. I can import MIBs correctly; I can navigate through the OID's tree...but the real question is:
What is the real task of the SAVE button? When I click on it nothing happen.
I thought It should save the "item" on the template selected....but...
I think that if I have to create the final templare manually, this feature (snmp_builder) is almost useless!
but I guess somewhere there is an error...
Help me please.Comment
Hmm. Everytime I click on this link, it sends me to a caf.xls sheet, which I'm not interested in opening.Fobius,
Anyone else having this issue?
-- JessComment
Anyone have a copy of this file?
Fobius,
http://wikisend.com/download/585042/zabbix22.tar.gzHi all,
That link is now serving yet another file which is not the 'zabbix22.tar.gz' archive. Does anyone have a copy of this file for us?
KorJek: Are you perhaps able to post an MD5 hash of the original file? Or better yet the file itself?Comment
