SNMP Builder for Zabbix
  • Peteris
    • Feb 2010
    • 89
    #91
    I downloaded SNMPv2-SMI.mib from internet
    But still there is an error:
    Attempt to define a root oid (iso): At line 9 in /usr/share/snmp/mibs/SNMPv2-SMI.mib
    • jhgrc
      • Jun 2009
      • 52
      #92
      It seems that your SNMP mib tries to define new root. So the SNMPv2 MIB probably is not correct one? Are you using net-snmp, try mibs from there.
      MIBs are are a tree structure. SNMPv2-SMI.mib has it own dependencies. So you need to download all MIBs. And some other MIB probably defines root OID, so your installed MIB cannot do it.
      • odium4u
        • Sep 2008
        • 20
        #93
        This addon works great, thank you for making this.
        I request only one feature if possible; a toggle for SNMP v2c or v1 queries. There are many devices that currently still use v1 as default/standard, NetApp filers being one.
        Thanks and keep up the great work.
        • jscleveland
          • Feb 2010
          Unknown Object Identifier (Index out of range: 0
          .iso.org.dod.internet.private.enterprises.trango.t bw.m5830sap.su.suInfoTable.suInfoEntry.suRSSIFromS U.0: Unknown Object Identifier (Index out of range: 0 (suID))
          It seems like the '0' on the end of the OID is the problem because walking the OID without the '0' works fine:
          snmpwalk -Os -c <mystring> -v 1 <myIP> 1.3.6.1.4.1.5454.1.20.3.6.1.16
          enterprises.5454.1.20.3.6.1.16.7 = INTEGER: -70
          enterprises.5454.1.20.3.6.1.16.11 = INTEGER: -73
          enterprises.5454.1.20.3.6.1.16.21 = INTEGER: -72
          enterprises.5454.1.20.3.6.1.16.24 = INTEGER: 0
          Any idea why the '0' gets appended?
          • r0k5t4r
            • Jun 2009
            • 91
            #95
            How to download the files?
            Hi, this might be a very very stupid question but how can I easily download snmpbuilder? In the text on your page it says unzip snmp_builder.zip. Where is the zip?
            • $0s
              • Apr 2010
              • 9
              #96
              "Download Source" button at the right-top
              • r0k5t4r
                • Jun 2009
                • 91
                #97
                LOL
                Thanks a lot. Was looking for it but couldn't find it.
                • $0s
                  • Apr 2010
                  • 9
                  #98
                  Hi All!
                  Zabbix 1.8.2 + freebsd 8.0
                  SNMP Builder show MIBs tree, but don't show mib tables.
                  In httpd-error.log:
                  Must have exactly one table name
                  USAGE: snmptable [OPTIONS] AGENT TABLE-OID
                    Version:  5.4.2.1
                    Web:      http://www.net-snmp.org/
                    Email:    [email protected]
                  OPTIONS:
                    -h, --help            display this help message
                   ................................................[all keys for snmptable command]
                    Version:  5.4.2.1
                  OPTIONS:
                  In what there can be a problem? Please help!
                  • uweiss
                    • Jun 2006
                    • 27
                    #99
                    Great tool! That should be integrated into the core.
                    Just trying it out because i want to monitor a BlackBerry server.
                    Added the BB MIB to the mibs directory and started browsing around. But whenever i click on a value (like the "routerBaseStatsPropertydevicesConnected" you see on the screen shot) i always get a "Wrong Type (should be INTEGER): NULL"
                    Executed snmpwalk from my Zabbix box and i get the correct value:
                    snmpwalk -v2c -c xxxx 172.30.3.4  .1.3.6.1.4.1.3530.6.7.35.20.5.1.4
                    SNMPv2-SMI::enterprises.3530.6.7.35.20.5.1.4.1.14 = INTEGER: 0
                    Don't know if the MIB itself is wrong ore something within snmp_builder.
                    Or is it becuase snmp_builder tries to access:
                    .1.3.6.1.4.1.3530.6.7.35.20.5.1.4.0
                    but the value is here:
                    .1.3.6.1.4.1.3530.6.7.35.20.5.1.4.14
                    Urs
                    • tothz
                      • Apr 2010
                      #100
                      menu error
                      Hy
                      I tried to install snmp_builder, but got a following error..If I change label in menu.inc.php to existing label (for example S_LOCALES) it works well...
                      The system zabbix 1.8.2.. Any idea?
                      thanks
                      zoltan
                      • asterroid
                        • May 2010
                        Hi, great stuff.
                        But I have a problem... I install it and when I click "SNMP Builder" of 'Administration Menu', in /var/log/httpd/error_log shows:
                        "PHP Fatal error: Class 'CWidget' not found in /var/www/html/snmp_builder.php on line 293, referer: http://zabbix.xxx.com/snmp_builder.php?sid=0267e50311f5d4ab."
                        Where is CWidget class? What's it?
                        Thanks you for all.
                        • elvar
                          • Feb 2008
                          • 226
                          #102
                          Any chance we'll see a version of this released soon which works with 1.8.2? I really like this addon.
                          Thanks!
                          • avtor01
                            • May 2010
                            Originally posted by $0s
                            Hi All!
                            In httpd-error.log:
                              Version:  5.4.2.1
                            OPTIONS:
                              Version:  5.4.2.1
                            OPTIONS:
                            I had a similar problem. It was connected with the fact that the script snmp_builder.php option to snmptable were listed in the wrong sequence. Verified in:
                            > snmptable -v 2c -c public -M /usr/local/share/snmp/mibs/ -m CISCO-RTTMON-MIB 172.17.10.1 rttMonCtrlOperTable -Ci -CH -Cf \",\"
                              Version:  5.4.2.1
                            , but:
                            > snmptable -v 2c -c public -M /usr/local/share/snmp/mibs/ -m CISCO-RTTMON-MIB -Ci -CH -Cf \",\" 172.17.10.1 rttMonCtrlOperTable
                            1","0:0:01:53.85","","0:0:00:00.00","10816","true","false","false","32442","2147483647 seconds","active","false
                            2","0:0:01:53.87","","0:0:00:00.00","10816","false","false","false","100710","2147483647 seconds","active","false
                            3","0:0:01:53.89","","0:0:00:00.00","10816","false","false","false","32143","2147483647 seconds","active","false
                            4","0:0:01:53.91","","0:0:00:00.00","10592","false","false","false","60158","2147483647 seconds","active","false
                            So I changed the line:
                            PHP Code:
                            exec("snmptable -v 2c -c $community -M ".MIBS_ALL_PATH." -m ALL $server_ip $oid -Ci -Ch -Cf \",\"", $results);
                            like so:
                            PHP Code:
                            exec("snmptable -v 2c -c $community -M ".MIBS_ALL_PATH." -Ci -Ch -Cf \",\" -m ALL $server_ip $oid ", $results);
                            , and:
                            PHP Code:
                            exec("snmptable -v 2c -c $community -M ".MIBS_ALL_PATH." -m ALL $server_ip $oid -Ci -CH -Cf \",\"", $results);
                            like so:
                            PHP Code:
                            exec("snmptable -v 2c -c $community -M ".MIBS_ALL_PATH." -Ci -CH -Cf \",\" -m ALL $server_ip $oid ", $results);
                            in file snmp_builder.php (lines 489 and 492). I hope this helps and you
                            PS Sorry for my English - it's all google translate
                            • $0s
                              • Apr 2010
                              • 9
                              #104
                              Great Thanks!!
                              It helps me!
                              • giapnguyen
                                • Aug 2009
                                • 33
                                #105
                                Thanks!
                                Unfortunately, I've switched my job and don't touch zabbix server any more . But I will try to revise 1.8.2 to help you guys soon.
                                I hope someone adopt the project for me. It really helpful. Some useful features I suggest
                                - Enter a oid to create zabbix item; sometimes you know an oid and don't want to navigate a tree to add new one. SNMPBuild help to convert oid into item automatically.
                                - Search oid by description, oid name so on
                                - Goto mass update after submit items.
