Possibility of showing live traffic for l7 protocols
  • william
    • Nov 2005
    Hi would it be possible to impliment a graph for showing the protocols and the amount of bandwidth they are using ie http, pop3, p2p, etc.. similiar to l7 protocols etc.
    Thanks Heaps
    William
  • tvman
    • Sep 2005
    • 21
    Normaly it could be done with netflow tools. It's standard de'facto. I would recomend NetFlow Analyzer4 from adventnet. They do have free edition. There are simplier free tools. But it's separate, pretty big task. It's possible to use SNMP with Cisco QoS tools to see traffic in different queues. But it's not that easy to use like counters on network interfaces.
    • william
      • Nov 2005
      Debian install
      Hi Tvman
      thanks for the info, had a look at NetFlow Analyzer4 and it seems to only be for redhat or windows.. am running debian sarge, do you know anyone using it for debian sarge?
      thanks heaps
      william
      • elkor
        • Jul 2005
        • 299
        the redhat .rpm should load just fine in debian make sure you have rpmtools available
        (this being said, I am not a debian guy. But the functionality to utilize the .rpms should be available)
        • tvman
          • Sep 2005
          • 21
          It should work without any problems because it's Java based server with shell scripting and mysql as a database. It has few issues but it possible to work it out.
          • Wolfgang
            • Apr 2005
            • 116
            Originally posted by william
            Hi Tvman
            thanks heaps
            william
            You might want to try alien on debian. Usally that works fine.
            http://www.intellitrend.de
            Specialised in monitoring large environments and Zabbix API programming.
            • bbrendon
              • Sep 2005
              • 873
              sorry to bring up cacti again
              A long time ago, i set cacti up to monitor queues.
              I'll PM you a link to what i created. Let me know if you want more info.
              Unofficial Zabbix Expert
              Blog, Corporate Site
