Option to Have Custom triggers severities & frontend messaging
  • RaulChiarella
    • Apr 2021
    • 59
    Hello there!
    I was searching for a solution for this and did not find any.
    Then i saw a discussion here on Zabbix Forum and thought it was a really good idea but it was on a different section - And it is pretty old... So i want to post it here.
    I am sorry if this is not the right place to post this but here it goes:
    It would benefit a lot of Zabbix Users to have a option on Trigger Severities to create custom severities and then select a custom audio for that new severity...
    Here:
Name:	Trigger Severities.png
    Example, lets say i want to create a new severity called "Update Complete"
    Then, on Frontend messaging i would select this "Update Complete" severity and bind to a custom audio i created using my own voice or TTS saying "Update on Server Complete"
    Or a severity saying "Backup Failed" and then i would bind to a audio saying "Backup on Server Failed"
    I am sorry if i didnt explained this right but i hope you all understood what i meant... I'm still training my English.
    PS: I know that this is possible using API... So i would just use a external software that reproduces sounds and all but would be very practical to have all this inside Zabbix.
  • splitek
    • Dec 2018
    • 101
    Why not use tags?
    Make tag "my_custom_severity" with value that you want like "update complete"
    • RaulChiarella
      • Apr 2021
      • 59
      Originally posted by splitek
      Why not use tags?
      Hello. I did not know of tags before... Its very useful.
      Thanks, i will definitely use this
        Come on.. "My toast is ready" is not a severity.....
