Feature-Q: admin comments+ history, wiki with page per host / hierarchy of hosts
  • Manfred
    • Aug 2023
    Hello!
    I am just evaluating Zabbix, which is a big bummer for a small community, but looks exciting.
    1)
    Usually, at the end of the day, there remain tasks ToDo, say for one or the other host or even individual items.
    I am looking for a history off administrative comments, which usually have (had) to be done on solving a problem,
    where it later shows, this was probably a wrong decision or the half of the problem. This is usually not to handle
    without the history of that item/host, which can be made, for example, in trac (in this case, I would use a wiki
    with one page per item and this could be seen as a simple history. Not all truth stem from automation!
    2)
    Is Zabbix able to display a tree of hosts? Say, on a physical machine, there are 3 KVM guest, which each
    hosting LXC containers.
    My question is, if somethings like this exists.
    Thanks anyway,
    Manfred​
  • Bendind
    • Aug 2023
    Hi Manfred,
    Zabbix does not have a built-in-feature for administrative comments or a history of actions taken on specific items or hosts. However, you can achieve this by using external tools like Trac, as you mentioned. By creating a wiki one page per item, you can maintain a simple history of administrative comments and decisions related to specific hosts or items. This can be a helpful way to track the context and decision-making process. Yes, Zabbix is capable of displaying a tree of hosts. You can host groups and organize your hosts in a hirerarchical structure.
      • 4993
      host tree and item tree widgets are in development .. listed in roadmap for v7.
      There is a frontend module from community to achieve this .. https://github.com/BGmot/zabbix-module-hosts-tree
      Zabbix allows adding comments to events.(Problems -> select your problem (tickbox) -> update -> add your comments)
