Static host group being mandatory for host prototype discovery
  • Ace
    • Jun 2021
    • 11
    When using host prototype discovery if you want to use a Group Prototype, a static host group is still required. Because of this every discovered host is now in 2 groups minimum, which just wastes space in the interface and since the static group will be filled with all types of hosts, it is unusable as well.
    I think it will be a great change to remove static groups from being mandatory when a group prototype is used.
    I can imagine the concern is discovered hosts being deleted if the host prototype changes but there are better ways to deal with that.
    • 4993
    Concern is not the host getting deleted but host left without a group.. Having a static group also at lest preserves your host and you can deal with the situation, withou t losing data... If discovered hostgroup just changes, that host is just reassigned to another group... I think.
    But then again, I can agree, it is not most elegant solution...
