SSL Certificate Issue with repo.zabbix.com on RHEL9 with FUTURE Crypto Policy
  • JeroenE
    • Apr 2024
    ## Problem Description
    I'm experiencing repository access issues when trying to install/update Zabbix on RHEL9 and derivates systems that have the crypto-policies set to `FUTURE`. The error occurs when dnf/yum tries to access the official Zabbix repository:
    Updating Subscription Management repositories.
    Zabbix Official Repository - x86_64 0.0 B/s | 0 B 00:01
    Errors during downloading metadata for repository 'zabbix':
    - Curl error (60): Peer certificate cannot be authenticated with given CA certificates for https://repo.zabbix.com/zabbix/6.0/r...ata/repomd.xml [SSL certificate problem: EE certificate key too weak]
    Error: Failed to download metadata for repo 'zabbix': Cannot download repomd.xml: Cannot download repodata/repomd.xml: All mirrors were tried
    ## Root Cause
    After investigating the SSL certificates, I found that:
    - **repo.zabbix.com** uses an RSA 2048-bit certificate
    - The FUTURE crypto policy requires RSA keys of 3072 bits or higher
    - Other repositories work fine because they use RSA 4096-bit certificates
    **Could the Zabbix team please upgrade the SSL certificate for repo.zabbix.com to use RSA 3072-bit (or higher) keys?**
    This would resolve the compatibility issue with: RHEL and Rocky systems using FUTURE crypto policy
    ## Environment Details
    - **OS:** Red Hat Enterprise Linux 9
    - **Crypto Policy:** FUTURE (`update-crypto-policies --set FUTURE`)
    - **Repository:** https://repo.zabbix.com/zabbix/6.0/rhel/8/x86_64/
    - **Issue:** RSA 2048-bit certificate rejected by FUTURE policy (requires 3072+ bits)
    Thanks for considering this enhancement!
  • JeroenE
    • Apr 2024
    Anyone who can help me with the posts problem?
    • Markku
      • Sep 2018
      • 1786
      I'd recommend opening a ticket at https://support.zabbix.com/
      Markku
      • Markku
        • Sep 2018
        • 1786
        Thanks for submitting https://support.zabbix.com/browse/ZBX-26701 , I see it got traction immediately
        Markku
