Active agents stopped reporting after upgrading to 1.6
  • Jason
    • Nov 2007
    • 431
    I've just upgraded from 1.4 to 1.6 and all of the active agents are showing as offline and unable to contact the zabbix server.
    the database upgrade ran through suspiciously quickly (5GB database) but I couldn't find any errors reported.
    Any ideas on this? Otherwise I'll have to revert back to 1.4 and I really like the new interface.
  • Jason
    • Nov 2007
    • 431
    Some more info... This is from the zabbix_server.log on the server.
    6486:20080924:101124 Trapper got [ZBX_GET_ACTIVE_CHECKS
    6486:20080924:101124 In send_list_of_active_checks()
    6486:20080924:101124 Query [select i.key_,i.delay,i.lastlogsize from items i,hosts h where i.hostid=h.hostid and h.status=0 and i.type=7 and h
    .host='shepherdsvr01.shepherd.local' and h.proxy_hostid=0 and (i.status=0 or (i.status=3 and i.nextcheck<=1222247484)) and h.hostid between 1000
    00000000000 and 199999999999999]
    6486:20080924:101124 Sending [agent.ping:90:0
    6486:20080924:101124 Error while sending list of active checks
    6486:20080924:101124 Trapper got [<req><host>c2VydmVyMDEuYmhsLmxvY2Fs</host><key>ZXZlbnRsb2dbQXBwbGljYXRpb25d</key><data>Q2xpZW50IGNvbXB1dGVyc
    yBhcmUgaW5zdGFsbGluZyB1cGRhdGVzIHdpdGggYSBoaWdoZXI gdGhhbiAyNSBwZXJjZW50IGZhaWx1cmUgcmF0ZS4gVGhpcyBpc yBub3Qgbm9ybWFsLg0K</data><lastlogsize>NDM3N
    TU=</lastlogsize><timestamp>MTIyMjI0MjI5OQ==</timestamp><source>V2luZG93cyBTZXJ2ZXIgVXBkYXRlIFNl cnZpY2Vz</source><severity>NA==</severity></req>
    ] len 396
    6486:20080924:101124 XML received [<req><host>c2VydmVyMDEuYmhsLmxvY2Fs</host><key>ZXZlbnRsb2dbQXBwbGljYXRpb25d</key><data>Q2xpZW50IGNvbXB1dGVy
    cyBhcmUgaW5zdGFsbGluZyB1cGRhdGVzIHdpdGggYSBoaWdoZX IgdGhhbiAyNSBwZXJjZW50IGZhaWx1cmUgcmF0ZS4gVGhpcyBp cyBub3Qgbm9ybWFsLg0K</data><lastlogsize>NDM3
    NTU=</lastlogsize><timestamp>MTIyMjI0MjI5OQ==</timestamp><source>V2luZG93cyBTZXJ2ZXIgVXBkYXRlIFNl cnZpY2Vz</source><severity>NA==</severity></req
    • Jason
      • Nov 2007
      • 431
      Hmmm... the debug on the agentd is
      5858:20080924:112635 Sending [ZBX_GET_ACTIVE_CHECKS
      hostname.ourdomain
      5858:20080924:112635 Before read
      5858:20080924:112655 Timeout while answering request
      5858:20080924:112655 Get active checks error: ZBX_TCP_READ() failed [Interrupted system call]
      5858:20080924:112655 Getting list of active checks failed. Will retry after 60 seconds
      5858:20080924:112755 get_active_checks('192.168.124.25',10051)
      It looks like the server isn't responding, but it worked fine before in 1.4.5...
      I've dumped and reloaded backup of DB and repatched and no errors, but still no joy.
      • Jason
        • Nov 2007
        • 431
        There is this thread from the 1.5.4 beta for a similar problem and it links to some code patch for trapper.c which apparently should be in 1.6, but I can't seem to find it in the 1.6 version. Adding the code from this patch fails because processed_fail isn't defined in process_new_values.
        from serverlog
        30943:20080924:122153 Error sending result back
        30943:20080924:122157 Error while sending list of active checks
        30943:20080924:122245 Error sending result back
        30943:20080924:122338 Error sending result back
        30943:20080924:122427 Error while sending list of active checks
        30943:20080924:122430 Error sending result back
        • Jason
          • Nov 2007
          • 431
          I've just done a completely fresh database as per the instructions with 1.6 and added an active agent to connect to it and no data comes in and the remote agent (1.4.5) reports a failed to connect to server suggesting that active agents are broken in the release version.
          I've reverted back to my 1.4 database and binaries and the agents are all reporting in again.
          The system is built on CentOS 5.2 64bit version. Has anyone else experienced this problem with active agents?
          • Antras
            • Oct 2007
            • 12
            Did you changed parameter StartAgents in the zabbix_agent.conf.
            I had the same problem, if StartAgents was 2. When i set it to 5 (default), everything began to work.
            • Jason
              • Nov 2007
              • 431
              I'll test that tomorrow... Surely that would only affect linux agents though and not windows agents?
              • Antras
                • Oct 2007
                • 12
                I've tested it only on my linux machines. Tomorrow will try on the windows too.
                • Jason
                  • Nov 2007
                  • 431
                  I still can't seem to get active agents to work at all either linux or windows. Some of the windows checks eventually check in (UserParameter ones only), but nothing from the rest.
                  On the agents I'm still getting
                  21905:20080926:093956 Getting list of active checks failed. Will retry after 60 seconds
                  21905:20080926:094116 Timeout while answering request
                  and on the zabbix server the mysql server appears maxed out at 100% cpu usage.
                  • Alexei
                    Founder, CEO
                    • Sep 2004
                    • 5654
                    This is interesting. What does 'mysqladmin processlist' show?
                    Alexei Vladishev
                    New York | Tokyo | Riga
                    My Twitter
                    • Jason
                      • Nov 2007
                      • 431
                      here is the processlist
                      | Id | User | Host | db | Command | Time | State | Info |
                      | 81070 | zabbix_user | localhost | zabbix2 | Query | 95 | Updating | update ids set nextid=nextid+1 where nodeid=1 and table_name='history_log' and field_name='id' |
                      | 81071 | zabbix_user | localhost | zabbix2 | Query | 3 | Updating | update ids set nextid=nextid+1 where nodeid=1 and table_name='history_log' and field_name='id' |
                      | 81072 | zabbix_user | localhost | zabbix2 | Sleep | 0 | | |
                      | 81073 | zabbix_user | localhost | zabbix2 | Query | 3 | Sorting result | select value from history_log where itemid=100100000022859 order by id desc limit 1 |
                      | 81074 | zabbix_user | localhost | zabbix2 | Query | 95 | Updating | update ids set nextid=nextid+1 where nodeid=1 and table_name='history_log' and field_name='id' |
                      | 81075 | zabbix_user | localhost | zabbix2 | Sleep | 6 | | |
                      | 81076 | zabbix_user | localhost | zabbix2 | Sleep | 24 | | |
                      | 81077 | zabbix_user | localhost | zabbix2 | Query | 0 | optimizing | select min(clock) from history where itemid=100100000022604 |
                      | 81080 | zabbix_user | localhost | zabbix2 | Sleep | 2 | | |
                      | 81081 | zabbix_user | localhost | zabbix2 | Sleep | 2 | | |
                      | 81084 | zabbix_user | localhost | zabbix2 | Sleep | 5 | | |
                      | 81085 | zabbix_user | localhost | zabbix2 | Sleep | 0 | | |
                      | 81086 | zabbix_user | localhost | zabbix2 | Sleep | 2 | | |
                      | 81087 | zabbix_user | localhost | zabbix2 | Sleep | 4 | | |
                      | 81088 | zabbix_user | localhost | zabbix2 | Sleep | 109 | | |
                      | 81089 | zabbix_user | localhost | zabbix2 | Sleep | 1 | | |
                      | 81090 | zabbix_user | localhost | zabbix2 | Sleep | 4 | | |
                      | 81113 | root | localhost | | Query | 0 | | show processlist |
                      Also something I just noticed from log file..
                      13199:20080929:094441 Query failed: [update ids set nextid=nextid+1 where nodeid=1 and table_name='history_log' and field_name='id'] Lock wait timeout exceeded; try restarting transaction [1205]
                      13195:20080929:094441 Query failed: [update ids set nextid=nextid+1 where nodeid=1 and table_name='history_log' and field_name='id'] Lock wait timeout exceeded; try restarting transaction [1205]
                      • Jason
                        • Nov 2007
                        • 431
                        Any ideas on this and a workaround?
                        • msklizmantas
                          • Jun 2008
                          i am experiencing similar issue:
                          Id User Host/IP DB Time Cmd Query or State
                          10864 zabbix localhost zabbix 0 Sleep
                          10868 zabbix localhost zabbix 0 Query commit
                          10871 zabbix localhost zabbix 0 Query commit
                          10874 saint localhost mysql 0 Query show full processlist
                          26 zabbix localhost zabbix 1 Query UPDATE ids SET nextid=nextid+1 WHERE nodeid=0 AND table_name='profiles' AND field_name='profil
                          515 zabbix localhost zabbix 1 Query UPDATE ids SET nextid=nextid+1 WHERE nodeid=0 AND table_name='profiles' AND field_name='profil
                          5257 zabbix localhost zabbix 1 Query UPDATE ids SET nextid=nextid+1 WHERE nodeid=0 AND table_name='profiles' AND field_name='profil
                          10853 zabbix localhost zabbix 1 Query commit
                          10860 zabbix localhost zabbix 1 Query delete from history_uint where itemid=19651 and clock<1222362731
                          10869 zabbix localhost zabbix 1 Query commit
                          10872 zabbix localhost zabbix 1 Query commit
                          10873 zabbix localhost zabbix 1 Query commit
                          22 zabbix localhost zabbix 2 Query UPDATE ids SET nextid=nextid+1 WHERE nodeid=0 AND table_name='profiles' AND field_name='profil
                          23 zabbix localhost zabbix 2 Query UPDATE ids SET nextid=nextid+1 WHERE nodeid=0 AND table_name='profiles' AND field_name='profil
                          24 zabbix localhost zabbix 2 Query UPDATE ids SET nextid=nextid+1 WHERE nodeid=0 AND table_name='profiles' AND field_name='profil
                          25 zabbix localhost zabbix 2 Query UPDATE ids SET nextid=nextid+1 WHERE nodeid=0 AND table_name='profiles' AND field_name='profil
                          58 zabbix localhost zabbix 2 Query UPDATE ids SET nextid=nextid+1 WHERE nodeid=0 AND table_name='profiles' AND field_name='profil
                          129 zabbix localhost zabbix 2 Query UPDATE ids SET nextid=nextid+1 WHERE nodeid=0 AND table_name='profiles' AND field_name='profil
                          207 zabbix localhost zabbix 2 Query UPDATE ids SET nextid=nextid+1 WHERE nodeid=0 AND table_name='profiles' AND field_name='profil
                          209 zabbix localhost zabbix 2 Query UPDATE ids SET nextid=nextid+1 WHERE nodeid=0 AND table_name='profiles' AND field_name='profil
                          429 zabbix localhost zabbix 2 Query UPDATE ids SET nextid=nextid+1 WHERE nodeid=0 AND table_name='profiles' AND field_name='profil
                          625 zabbix localhost zabbix 2 Query UPDATE ids SET nextid=nextid+1 WHERE nodeid=0 AND table_name='profiles' AND field_name='profil
                          10876 zabbix localhost zabbix 2 Query UPDATE ids SET nextid=nextid+1 WHERE nodeid=0 AND table_name='profiles' AND field_name='profil
                          381 zabbix localhost zabbix 3 Query UPDATE ids SET nextid=nextid+1 WHERE nodeid=0 AND table_name='profiles' AND field_name='profil
                          416 zabbix localhost zabbix 3 Query UPDATE ids SET nextid=nextid+1 WHERE nodeid=0 AND table_name='profiles' AND field_name='profil
                          540 zabbix localhost zabbix 3 Query UPDATE ids SET nextid=nextid+1 WHERE nodeid=0 AND table_name='profiles' AND field_name='profil
                          624 zabbix localhost zabbix 3 Query UPDATE ids SET nextid=nextid+1 WHERE nodeid=0 AND table_name='profiles' AND field_name='profil
                          10857 zabbix localhost zabbix 3 Sleep
                          10870 zabbix localhost zabbix 3 Sleep
                          165 zabbix localhost zabbix 4 Query UPDATE ids SET nextid=nextid+1 WHERE nodeid=0 AND table_name='profiles' AND field_name='profil
                          10677 zabbix localhost zabbix 4 Query UPDATE ids SET nextid=nextid+1 WHERE nodeid=0 AND table_name='profiles' AND field_name='profil
                          5263 zabbix localhost zabbix 5 Query UPDATE ids SET nextid=nextid+1 WHERE nodeid=0 AND table_name='profiles' AND field_name='profil
                          10863 zabbix localhost zabbix 5 Sleep
                          57 zabbix localhost zabbix 6 Query UPDATE ids SET nextid=nextid+1 WHERE nodeid=0 AND table_name='profiles' AND field_name='profil
                          490 zabbix localhost zabbix 6 Query UPDATE ids SET nextid=nextid+1 WHERE nodeid=0 AND table_name='profiles' AND field_name='profil
                          10788 zabbix localhost zabbix 6 Query UPDATE ids SET nextid=nextid+1 WHERE nodeid=0 AND table_name='profiles' AND field_name='profil
                          web frontend can't even load.
                          • disgruntleddutch
                            • Oct 2006
                            • 34
                            Yup this is the same exact problem I encountered.
                            Active checks failing and the mysqld process ramping up to the max of box which in my case is 400%. Not very fun and it forces the use of non-active agents everywhere :-(.
                            • dantheman
                              • May 2006
                              • 209
                              #15
                              I also have the same behavior where my active agents have failed to work after the upgrade to 1.6, but my mysql is staying low (between 0-30 percent).
