Active agents stopped reporting after upgrading to 1.6
  • NOB
    • Mar 2007
    • 469
    #16
    Originally posted by Antras
    Did you changed parameter StartAgents in the zabbix_agent.conf.
    I had the same problem, if StartAgents was 2. When i set it to 5 (default), everything began to work.
    If you did that in 1.4.x, the agent wouldn't have send any active data,
    at all.
    We tried it and it didn't. You have to have at least 5 set for this parameter to send active data.
    HTH,
    Norbert.
    • NOB
      • Mar 2007
      • 469
      #17
      Originally posted by dantheman
      I also have the same behavior where my active agents have failed to work after the upgrade to 1.6, but my mysql is staying low (between 0-30 percent).
      We have server 1.6 (fresh install) and an 1.6 agent (both on Solaris 9 SPARC)
      running fine, even with active checks.
      But we suffer from the agent crash under Windows as well.
      Time to replace Windows and Linux by Solaris
      Yesterday we even were successful in connecting a Linux (intel) Proxy
      to this 1.6 server and it seems to work fine, i.e. active checks from the agent monitored by the Proxy, SNMP checks, Ping checks all done by the Proxy.
      Proxy is running on Ubuntu using SQLite3.
      Regards
      Norbert.
      • Jason
        • Nov 2007
        • 431
        #18
        Have any of these issues been fixed in the development releases? If so might take a look...
        Otherwise can provide more debug information if I know whats required.
        • tekknokrat
          • Sep 2008
          • 140
          #19
          I have active checks running between agentd and master server.
          Will test active checks between proxy and agentd later.
          I had to use the hostname instead of ip-address for
          Hostname=
          in agentd.conf.
          Is this correct behaviour? For proxy config setting IPAddress suffices.
          • Jason
            • Nov 2007
            • 431
            #20
            For active checks hostname in the agent file should exactly match the hostname in zabbix.
            That is already the case for all of my servers, but still no joy on 1.6
            • Jason
              • Nov 2007
              • 431
              #21
              Some extra info to see if it helps...
              # ldd zabbix_server
              libcurl.so.3 => /usr/lib64/libcurl.so.3 (0x0000003ca0000000)
              libgssapi_krb5.so.2 => /usr/lib64/libgssapi_krb5.so.2 (0x0000003ca5000000)
              libkrb5.so.3 => /usr/lib64/libkrb5.so.3 (0x0000003ca3800000)
              libk5crypto.so.3 => /usr/lib64/libk5crypto.so.3 (0x0000003ca5800000)
              libcom_err.so.2 => /lib64/libcom_err.so.2 (0x0000003ca3000000)
              libresolv.so.2 => /lib64/libresolv.so.2 (0x0000003ca2c00000)
              libdl.so.2 => /lib64/libdl.so.2 (0x0000003c9e000000)
              libidn.so.11 => /usr/lib64/libidn.so.11 (0x0000003c9f000000)
              libssl.so.6 => /lib64/libssl.so.6 (0x0000003ca7c00000)
              libcrypto.so.6 => /lib64/libcrypto.so.6 (0x0000003ca1c00000)
              libz.so.1 => /usr/lib64/libz.so.1 (0x0000003c9ec00000)
              libnetsnmp.so.10 => /usr/lib64/libnetsnmp.so.10 (0x0000003c9f400000)
              libm.so.6 => /lib64/libm.so.6 (0x0000003c9e400000)
              libwrap.so.0 => /usr/lib64/libwrap.so.0 (0x00002aea9fbdc000)
              libmysqlclient.so.15 => /usr/lib64/mysql/libmysqlclient.so.15 (0x0000003c9e800000)
              libc.so.6 => /lib64/libc.so.6 (0x0000003c9dc00000)
              libkrb5support.so.0 => /usr/lib64/libkrb5support.so.0 (0x0000003ca5c00000)
              libkeyutils.so.1 => /lib64/libkeyutils.so.1 (0x0000003ca5400000)
              /lib64/ld-linux-x86-64.so.2 (0x0000003c9d800000)
              libnsl.so.1 => /lib64/libnsl.so.1 (0x0000003ca0c00000)
              libcrypt.so.1 => /lib64/libcrypt.so.1 (0x0000003caea00000)
              libselinux.so.1 => /lib64/libselinux.so.1 (0x00002aea9fde7000)
              libsepol.so.1 => /lib64/libsepol.so.1 (0x0000003c9f800000)
              Linux zabbix 2.6.18-92.1.6.el5 #1 SMP Wed Jun 25 13:45:47 EDT 2008 x86_64 x86_64 x86_64 GNU/Linux
              mysql Ver 14.12 Distrib 5.0.45, for redhat-linux-gnu (x86_64) using readline 5.0
              • gjtje
                • Apr 2006
                Here too all active checks are dead after updating to 1.6, both linux and Windows agents. The Windows 1.6 agent crashes right after starting...
                Gentoo system with a manual installation of zabbix 1.6.
                • dantheman
                  • May 2006
                  • 209
                  #23
                  I downloaded the latest 1.6 version from the development branch, and am able to start the 1.6 agent, but still am still seeing the same problem where the active checks are not functioning.
                  • dantheman
                    • May 2006
                    • 209
                    #24
                    Is anyone else still dealing with this issue?
                    I have had to switch all my checks to type "zabbix agent" until this is working again, which is putting more of a load on my zabbix server.
                    • Jason
                      • Nov 2007
                      • 431
                      #25
                      I've had to revert back to 1.4... 90% of my agents are remote and I can't poke holes in all those firewalls just to allow zabbix communications...
                      If a patch comes out for this issue then I'll happily test it...
                      Fixing it is beyond my programming skills though
                      • dantheman
                        • May 2006
                        • 209
                        #26
                        I think I have figured out my problem with this, the hostname in the web interface and in the agent.conf file are now case sensitive. I was looking really closely and realized that i had a few agents that were working and some that weren't.
                        The ones that weren't working the case was different in the agent.conf file from what I had in the web interface. Apparently that didn't matter in previous versions of zabbix, but does now.
                        Dan
                        • Jason
                          • Nov 2007
                          • 431
                          #27
                          All my hostnames are deliberately in lowercase both in config files and in zabbix.
                          • YvesM
                            • Jul 2008
                            • 14
                            #28
                            I have the same problem with the windows client 1.6
                            Hi, I have made the update from 1.4.5 to 1.6. I have also the problem with the active client check. I Have an Item for eventlog[Application]. I tried the client 1.4.5 and also the 1.6. The 1.6 client crashed after the start of the service in windows. The client 1.4.5 funktion. The server 1.6 didn't collect data from the eventlog when I change it to Zabbix active check. When I put the item back to Zabbix agent then I get the message in the Data filed that I must change to active check to get data.
                            Will be a patch released to resolve this problem????
                            Thx in advance
                            • bbrendon
                              • Sep 2005
                              • 870
                              #29
                              I never made it to v1.6 because this version has been working flawless. I didn't see the point of upgrading if I wasn't experiencing any bugs
                              ZABBIX Server (daemon) v1.5.4 (19 August 2008)
                              Compilation time: Aug 25 2008 11:40:46
                              Are you using 1.6.0 or a newer build? I would try something newer.
                              Unofficial Zabbix Expert
                              Blog, Corporate Site
                              • YvesM
                                • Jul 2008
                                • 14
                                #30
                                I use the server Version deamon 1.6 and the client version 1.4.5 or 1.4.6 or 1.5.2
