Hi all,
1) The problem
Some graphs automatic generated in the section "Latest data" in the Monitoring Section are build with some blank spaces. Here a screenshot:
It seens that the problem just happens with line style graphs, and just when I start to monitor more than 40 servers.
Other graphs do not show this problem, even with more than 40 server monitored.
2) Some info about my enviroment
Zabbix version 1.6
FreeBSD 7.0
Intel Quad Core Q6600 (2.40GHz, 2x4MB L2 Cache, 1066MHz)
4GB RAM
About the machine load:
last pid: 47995; load averages: 0.07, 0.11, 0.09
CPU states: 0.2% user, 0.1% nice, 0.6% system, 0.0% interrupt, 99.2% idle
Number of hosts (monitored/not monitored/templates) 102 54 / 0 / 48
Number of items (monitored/disabled/not supported) 2640 2597 / 1 / 42
Number of triggers (enabled/disabled)[true/unknown/false] 1109 1096 / 13 [13 / 216 / 867]
Required server performance, new values per second 120.9668 -
I think it is not a performance problem, as you can see, the machine is fine.
Anyone has any tip?
Thanks a lot!
Felipe
1) The problem
Zabbix version 1.6
FreeBSD 7.0
4GB RAM
Anyone has any tip?
Thanks a lot!
Felipe
