Acknowledges don't show under Triggers
  • oneye
    • May 2008
    • 27
    Hello to you all
    I have upgraded to 1.6.1 from 1.6 and I still see the same problem. So if I add acknowledgement under "Dashboard" I see "Ack Yes" and a pop up if I go across it with my mouse. I also see a check (trigger was acknowledged) if I look under "Overview". But if I look under "Triggers" there is nothing under "Acknowledged".
    Thanks and regards!
  • oneye
    • May 2008
    • 27
    my bad...i didn't see this thread
