Active Agent problems since 1.4
  • bluelinq
    • Feb 2008
    • 44
    Is there a reason why this should not work as an Active Agent?
    perf_counter[\PhysicalDisk(_Total)\Avg. Disk Read Queue Length]
    This stopped working when I upgraded from 1.4.6 to 1.6 and is the same in 1.6.1 and is really a shame as most of the people have some desire of using remote agents.
    The server is running CentOS 5.2.
    Regards,
    Paul
  • bbrendon
    • Sep 2005
    • 873
    I don't see a problem with that. I haven't upgraded any of my agents because of various reports of issues i've read like yours.
    Revert back to 1.4?
    Unofficial Zabbix Expert
    Blog, Corporate Site
    • bluelinq
      • Feb 2008
      • 44
      The issue is not with the agents, it is with the zabbix server itself. I reverted back to server 1.4.6 and all agents reported perfectly without any changes on their side so this is a server issue. I kept the GUI at 1.6 and so far so good.
      I have not seen any official posting regarding this and reverting to 1.4 while is a bandaid not a solution. It will be great if anyone at Zabbix Corp makes any suggestions as to where the problem may be and perhaps the community can work together to find a solution. My two cents anyway.
      Regards,
      Paul
      • bbrendon
        • Sep 2005
        • 873
        Strange. You're saying that 1.4 agents won't report windows perf counters to a 1.6 server, but they work with 1.4 server?
        That seems very odd. I would look at your debug logs for the agent and server.
        • bluelinq
          • Feb 2008
          • 44
          yes, that is exactly what I am saying. Nothing on the agend logs, the issue is not in the agents, but in the server software. On the server side if I enable debug logging it generates all kinds of entries, but nothing for me that will be able to help me find the issue. The servers I maintain are remote and stopped reporting when I upgraded to 1.6. They autmatically started working again by reinstalling 1.4.6 server.
          I cannot be the only one having this issue.
          • bbrendon
            • Sep 2005
            • 873
            What does your zabbix_server config file look like? I seem to recall something about incorrect nodeid settings causing issues.
            Is it just Windows Perf counters or are values not working?
            Sorry, I can't be of more help.
            Check out this thread, it might help
