False SSH alerts
  • nibb
    • Oct 2008
    • 78
    False SSH alerts
    Im getting false SSH server down/up alerts.
    Sometimes its ok and all servers and suddently its down on one and up on another. This is a false check of course since SSH is always up on all servers. It seems to randomly appear and dissappear.
  • Alexei
    Founder, CEO
    • Sep 2004
    • 5654
    Do not use default templates. You may want to make your triggers less sensitive using trigger functions min/max, instead of last().
    Alexei Vladishev
    New York | Tokyo | Riga
    My Twitter
    • nibb
      • Oct 2008
      • 78
      Thanks will try that since im getting this now also on password change.
      Can I change this per server trigger instead of the whole template which changes all?
      • Crazy Marty
        • Sep 2007
        • 75
        Alexei, if the default templates are broken enough that you recommend against using them, why not put some effort into fixing them? I'm sure that if you offered a few guidelines, there would be lots of folks here who would provide more useful templates for distribution....
        • bbrendon
          • Sep 2005
          • 873
          I must agree. The defaults are pretty bad.
          Unofficial Zabbix Expert
          Blog, Corporate Site
          • Alexei
            Founder, CEO
            • Sep 2004
            • 5654
            They are not broken. I tend to agree with you that the default templates should be improved. Yes, more documentation may help as well.
            Alexei Vladishev
            My Twitter
            • nibb
              • Oct 2008
              • 78
              Why do you mean they are pretty bad? Actually they work quite well for me. The only thing i had false alerts with it is the SSH and password changes.
              Why dont we all start by saying what can be done on the default templates instead of just saying they need to be improved.
