Problems installing Zabbix on Fedora 10
  • Zebedee0026
    • Mar 2008
    • 12
    got a problem with getting the web interface open in fedora 10
    i have yum installed zabbix, zabbix-server-mysql, zabbix-web-mysql and created the database, I have configure zabbix-server to use the local database.
    but when i go to the zabbix web interface I get
    Undefined index: TYPE[/etc/zabbix/db.inc.php:606]
    then in a box i get "ZABBIX is temporary unavailable!" then a retry box.
    please help!
  • wakko
    • Dec 2008
    • 19
    I ran into this as well. The short answer is, the web UI isn't properly redirecting to the installer.
    To fix this, you just need to manually create /etc/zabbix/zabbix.conf.php
    Here's mine:
    PHP Code:
    <?php
    ** ZABBIX
    ** Copyright (C) 2000-2005 SIA Zabbix
    ** This program is free software; you can redistribute it and/or modify
    ** it under the terms of the GNU General Public License as published by
    ** the Free Software Foundation; either version 2 of the License, or
    ** (at your option) any later version.
    ** This program is distributed in the hope that it will be useful,
    ** but WITHOUT ANY WARRANTY; without even the implied warranty of
    ** MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
    ** GNU General Public License for more details.
    ** You should have received a copy of the GNU General Public License
    ** along with this program; if not, write to the Free Software
    ** Foundation, Inc., 675 Mass Ave, Cambridge, MA 02139, USA.
    global $DB;
    $DB["TYPE"]             = "MYSQL";
    $DB["SERVER"]           = "localhost";
    $DB["PORT"]             = "0";
    $DB["DATABASE"]         = "zabbix";
    $DB["USER"]             = "zabbix";
    $DB["PASSWORD"]         = "password";
    $ZBX_SERVER             = "localhost";
    $ZBX_SERVER_PORT        = "10051";
    $IMAGE_FORMAT_DEFAULT   = IMAGE_FORMAT_PNG;
    • Zebedee0026
      • Mar 2008
      • 12
      Working
      Thanks for the help it working at last!!!
      but i have no images or graphs any ideas?
      • wakko
        • Dec 2008
        • 19
        Could you be more specific? What images and graphs are you expecting to find?
        Did you forget import the schema and data from /usr/share/doc/zabbix-server-%{version}/schema and /usr/share/doc/zabbix-server-%{version}/data ?
        • Zebedee0026
          • Mar 2008
          • 12
          I imported the schema, data and the images as per normal
          I can't see any images or grapth graphics dynamically created!
          • Nomad-71
            • Mar 2009
            I have encountered the same problem - there is no graphs. Have you solved it?
            • Nomad-71
              • Mar 2009
              I have solved this problem. Just download sources and copy files from "frontends/php" to "/usr/share/zabbix" ( I have deleted all files from /usr/share/zabbix before copying )
              • simix
                • Jul 2006
                • 53
                Maybe you should inform the package maintainer so that he can fix it.
