Housekeeper and db
  • antani
    • Apr 2008
    • 50
    Housekeeper and db
    My history_log.ibd is 8GB. I checked in my zabbix_server.log grepping for housekeeper and it shows no results. Log verbosity is set to 4. Zabbix (agent|server) version is 1.6.1
    What can I do to:
    - Shrink that table
    - Manually run housekeeper
    - Understand why housekeeper is not running anymore.
  • Alexei
    Founder, CEO
    • Sep 2004
    • 5654
    Option #4, understand why grepping for housekeeper displayed no results.
    Alexei Vladishev
    New York | Tokyo | Riga
    My Twitter
    • antani
      • Apr 2008
      • 50
      I think that is because housekeeper is not running.
      • mschlegel
        • Oct 2008
        • 40
        With logging at level 4, zabbix server will cycle log files very quickly. As a result, housekeeper is probably running (as long as you didn't disabled it in zabbix_server.conf), but the log entries about the housekeeper running get cycled out of the log file almost immediately. Try running your server at log level 3 for a while and see if the housekeeper log entries show up as expected.
