Warning: ZABBIX semaphores already exist,$
  • Han
    • Apr 2005
    • 23
    Hello all,
    We use zabbix 1.6 on debian etch, last week Zabbix is stop working.
    When we start zabbix-server there is no error message, but the log file gives /usr/local/sbin/zabbix_server [3334]: Warning: ZABBIX semaphores already exist,$
    Logfile>
    2562:20090209:224737 **** Enabled features ****
    2562:20090209:224737 SNMP monitoring:YES
    2562:20090209:224737 WEB monitoring:YES
    2562:20090209:224737 Jabber notifications: YES
    2562:20090209:224737 ODBC:NO
    2562:20090209:224737 IPv6 support:NO
    2562:20090209:224737 **************************
    2562:20090209:224739 ZABBIX semaphores already exist, trying to recreate.
    2562:20090209:224739 Listener failed with error: Cannot bind to port 10051 fo$
    /usr/local/sbin/zabbix_server [3334]: Warning: ZABBIX semaphores already exist,$[/B]
    3334:20090209:230318 Starting zabbix_server. ZABBIX 1.6.
    3334:20090209:230318 **** Enabled features ****
    3334:20090209:230318 SNMP monitoring:YES
    3334:20090209:230318 WEB monitoring:YES
    3334:20090209:230318 Jabber notifications: YES
    3334:20090209:230318 ODBC:NO
    3334:20090209:230318 IPv6 support:NO
    3334:20090209:230318 **************************
    Someone any ideas to fix this.
    Kind regards
    Han van Eijden
  • bbrendon
    • Sep 2005
    • 873
    Hmm. My memory isn't working that far back... you are probably running into a bug that has been fixed. You should update to 1.6.2 or 1.6.3pre if you're using SNMP.
    Unofficial Zabbix Expert
    Blog, Corporate Site
    • Alexei
      Founder, CEO
      • Sep 2004
      • 5654
      I do not think there are any bugs, probably just extensive debug output. Pay close attention to another problem, the port is already used:
      Alexei Vladishev
      New York | Tokyo | Riga
      My Twitter
      • bbrendon
        • Sep 2005
        • 873
        Good eye
        • rxm8028
          • Apr 2005
          • 45
          Port already in use
          I have seen this same problem appear on my zabbix_agentd. I noticed that I wasn't getting remote commands executed on the client, so I attempted to restart the zabbix_agentd daemon. I have debug set to 4, and all I see is this message:
           Listener failed with error: Cannot bind to port 10050 for server [ANY]. Error [Address already in use]. Another zabbix_agentd already running ?.
          Nmap reports that the ports 10050 and 10051 are closed.
          Any suggestions? This was working fine before the weekend.
          Regards,
          Ross
          • richlv
            • Oct 2005
            • 3112
            netstat -ntpl
            check for whatever is running on that port
            • remnts
              • Nov 2012
              • 14
              Regards,
              Ross
              I have the same error with the agent version 1.4.1 on debian lenny, somebody have a solution for this issue? help pliss
