net.if.in[eth0,bytes] don't work!
  • TAiS46
    • Dec 2008
    on Server 1 i have Zabbix Server and on Server 2 i have the agentd.
    If i check net.if.in[eth0,bytes] on server 2 with:
    zabbix_agentd -t net.if.in[eth0,bytes]
    i will get
    net.if.in[eth0,bytes] [u|1957288393689]
    But if the server is askin the server 2 i will get the error in the agentd log:
    016778:20090325:224615 Got line:net.if.in[eth0,bytes]
    016778:20090325:224615 Sending back:ZBX_NOTSUPPORTED
    What is the error?????
    Thank you, Greetings Simon
  • TAiS46
    • Dec 2008
    ~~~push~~~
    • side_control
      • Mar 2008
      • 37
      What OS are you running? When I ran my zabbix_agentd on freebsd, eth0 obviously didn't work, I had to change it to em0 and it started working.
      • TAiS46
        • Dec 2008
        running debian! em0 dosen't work!
        • rue
          • May 2006
          • 43
          Does the hostname in GUI and in agent config match exactly?
          cheers
          Rü
          • TAiS46
            • Dec 2008
            Yes!
            vfs.fs.size[/home,pused]
            system.cpu.load[,avg1]
            system.cpu.load[,avg15]
            system.cpu.load[,avg5]
            They are working!
            Is not Working!
            • rue
              • May 2006
              • 43
              Strange! If the other key_s work, try raising DebugLevel in zabbix_agentd.conf to "4" and we might see what's happening there... .
              Cheers
              Rü
              • chinasunysh
                • Mar 2009
                modify your netinterface on your system like this:
                #/sbin/ifconfig
                bge0: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> mtu 1500
                options=1b<RXCSUM,TXCSUM,VLAN_MTU,VLAN_HWTAGGING>
                ether 00:1b:fc:f3:34:8b
                media: Ethernet autoselect (100baseTX <full-duplex>)
                status: active
                net.if.in[bge0,bytes]
                • TAiS46
                  • Dec 2008
                  Where can i find the netinterface on debian?
                  • rue
                    • May 2006
                    • 43
                    /etc/network/interfaces
                    cheers
                    Rü
                    • TAiS46
                      • Dec 2008
                      In the file i have this:
                      # This file describes the network interfaces available on your system
                      # and how to activate them. For more information, see interfaces(5).
                      # The loopback network interface
                      auto lo
                      iface lo inet loopback
                      auto eth0
                      iface eth0 inet static
                              address 91.121.124.18
                              netmask 255.255.255.0
                              network 91.121.124.0
                              broadcast 91.121.124.255
                              gateway 91.121.124.254
                      auto eth1
                      iface eth1 inet static
                              address 91.121.125.18
                              network 91.121.125.0
                              broadcast 91.121.125.255
                      up /sbin/ip route add default via 91.121.125.254 dev eth1 table 125
                      up /sbin/ip rule add from 91.121.125.18/32 table 125
                      post-down /sbin/ip rule del from 91.121.125.18/32 table 125
                      post-down /sbin/ip route del default via 91.121.125.254 dev eth1 table 125
