1.6.3 very High Load
  • 753713
    • Apr 2006
    • 137
    ater upgrade from 1.6.2 to 1.6.3 I have very high Load on my Zabbix Server ~7-9, and my Windows Eventlog Monitoring is no running on all Windows Server.
    After downgrade is my Load ~2-3 and the Zabbix Server running perfectly without errors.
    any ideas for my problem with the version 1.6.3
    thanks
    753713
    ______________________________
    Version : 2.0.x
    Server OS: Ubuntu 12.04
    Zabbix Servers: 12
    Monitored Windows Server: ~ 1000
  • bbrendon
    • Sep 2005
    • 872
    What parts of zabbix did you upgrade/downgrade?
    Unofficial Zabbix Expert
    Blog, Corporate Site
    • Alexei
      Founder, CEO
      • Sep 2004
      • 5654
      This is hard to believe. Zabbix 1.6.3 introduced some features which makes it run faster, not slower!
      Alexei Vladishev
      New York | Tokyo | Riga
      My Twitter
      • 753713
        • Apr 2006
        • 137
        with zabbix_server 1.6.2 running my server perfektly, after change zabbix_server to 1.6.3 running my server with load ~7-9.
        Frontend replace has no impacts os server load.
        Version : 2.0.x
        Zabbix Servers: 12
        • Alexei
          Founder, CEO
          • Sep 2004
          • 5654
          Anyone else having similar issues?
          Alexei Vladishev
          My Twitter
          • bimind
            • Sep 2008
            • 25
            I have the same problem.
            After the update from 1.6.2 to 1.6.3 CPU load and CPU utilization have increased in my zabbix
            I updated the binaries and frontend.
            Thanks,
            Oriol
            • bimind
              • Sep 2008
              • 25
              The CPU graph after upgrade
              • 753713
                • Apr 2006
                • 137
                in the version 1.6.4 is the load also very high
                Version : 2.0.x
                Zabbix Servers: 12
                • jmcnulty
                  • Nov 2008
                  • 33
                  New indexes?
                  Have those of you experiencing problems here created the indexes advised on the Zabbix 1.6.4 information page?
                  I've upgraded but have not done this yet as I'm not sure of the exact steps required.
                  John
                  • bimind
                    • Sep 2008
                    • 25
                    The problem appears with and without the indexes.
                    Oriol
                    • t2y
                      • Feb 2009
                      • 60
                      Hi Oriol,
                      I'm interested in this topic. Do you mean that we should create as follows indexes which were written by Release Note?
                      CREATE UNIQUE INDEX history_log_2 on history_log (itemid,id);
                      CREATE UNIQUE INDEX history_text_2 on history_text (itemid,id);
                      CREATE INDEX graphs_items_2 on graphs_items (graphid);
                      • 753713
                        • Apr 2006
                        • 137
                        I have install upgrade to 1.6.4 and the index is create.
                        1. with 1.6.3 I have very high load ~7-9 and my Windows Eventlog Monitoring is not running.
                        2. with 1.6.4 I have high load ~5-7 and my Windows Eventlog Monitoring running perfectly.
                        Any Ideas how can I the load smaller configure?
                        Version : 2.0.x
                        Zabbix Servers: 12
                        • bimind
                          • Sep 2008
                          • 25
                          Hi everybody,
                          Any news about this thread? I continued with the problem!
                          Thanks,
                          Oriol
                          • Kerrygeek
                            • Dec 2008
                            • 115
                            Originally posted by t2y
                            Hi Oriol,
                            I just upgraded my test box from 1.6.1 to 1.6.4 hoping to get away from the memory leak problem. Is there any reason I can't go ahead and make these indexes on my 1.6.2 production server before I do the upgrade?
                            Thanks,
                            Kerry
                            • Kerrygeek
                              • Dec 2008
                              • 115
                              #15
                              I upgraded my Zabbix server over the weekend and also built the indexes listed earlier in this thread. My utilization seems to be down, I'll have to let it run a while to determine if the memory leak is fixed but so far it looks fine. I had a cron job set up to restart Zabbix every morning, I've disabled it so we'll see if it still uses up all my memory.
                              And, for those of you who posted upgrade instructions, thanks! It was a big help and should be included in the next version of the manual.
                              Kerry
