problem install zabbix_agentd.conf NT4.0 server
  • Raik
    • May 2009
    Hello
    I've tried to install the zabbix agent version 1.6.4 at an NT4.0_SP6a server. I followed the install dokumentation (download and install pdh.dll from Microsoft).
    1.)
    I used zabbix_agentd.exe --install and get only an error message: "c:\zabbix_agentd.exe is not a valid Windows NT application".
    2.)
    I used zabbix_agent-1.6.4_installer from http://www.suiviperf.com/zabbix/
    logfile details:
    Output folder: C:\Program Files\Zabbix Agent
    Extract: zabbix_agentd.exe... 100%
    Extract: zabbix_agentd.conf... 100%
    Extract: License.txt... 100%
    Extract: README.txt... 100%
    Copy failed
    Registering Zabbix Agent in services...
    Error installing Agent
    Created uninstaller: C:\Program Files\Zabbix Agent\uninstall.exe
    Completed
    An installation on W2k3 og Ubuntu8.04LTS with the same sourcefiles is not a problem. I tried the installation at 3 NT4.0SP6a server og evertime cames the same error message.
    I hope anyone has an idea which can help me.
    Raik
  • rue
    • May 2006
    • 43
    Originally posted by Raik
    Hello
    1.)
    2.)
    logfile details:
    Copy failed
    Completed
    Raik
    Interesting! Can you start the binary on the server? (C:\Program Files\Zabbix Agent\zabbix_agentd.exe). Log output suggest, that only the "install as service" failed, which you could also do manually, if the agent starts at all... .
    Cheers
    RĂ¼
    • Raik
      • May 2009
      No, there comes the same error message (no NT application). I checked also the registry, there is no zabbix_agent key installed.
      Raik
      • Raik
        • May 2009
        Has anybody successfully installed at zabbix_agent_1.6.4 at an NT4.0 server? And if yes, which installscript, NT-config (patchlevel etc.) did you use?
        Raik
        • slmeyer
          • Aug 2008
          • 10
          Raik
          No, I tried earlier version (1.4.6) also no luck
          • sarathyme
            • Mar 2009
            • 58
            Not able to install Zabbix Agent on NT 4.0
            Not able to install Zabbix Agent on NT 4.0, does any body faced this error?
            I get an error message saying zabbix_agentd is not a Windows NT Application.
            Thanks in advance for any pointers.
            Regards
            Vijay
            • rmiddleswarth
              • Feb 2011
              Were any of you able to get the agent to run.
              Robert
              • sarathyme
                • Mar 2009
                • 58
                Agent V 1.4.4 works on NT 4.0.
                Plz refer to
                Vijay
