Access the same log file with several zabbix_agentd
  • nono77
    • May 2009
    We have a cluster configuration (solaris/VCS - 5 nodes) with several zabbix_agentd on the same node each one with logical IP/hostname . My problem is that i can access the /var/adm/messages ( log active check) only with one zabbix_agentd.
    It is possible to access one log file with several zabbix_agentd on the same host ?
    Thank's for your suggestion.
  • richlv
    • Oct 2005
    • 3112
    you are probably referring to the logfile check.
    i don't see why wouldn't that be possible, so i can only suggest to check file permissions for zabbix agents that fail to access it.
    • exkg
      • Mar 2007
      • 718
      But ... what ZABBIX log file says about this ? Have you some error in ZABBIX log files ?
      Is needed say that zabbix agent didnt tak exclusive acces in log files.
      []s,
      Luciano
      Luciano Alves
      www.zabbix.com
      Brazil | México | Argentina | Colômbia | Chile
      Zabbix Performance Tuning
      • pesadilla
        • Nov 2006
        • 69
        i think is a problem with lock/truncate files
        unset LogFile and use "syslog" to avoid problem with multiple access to single file
        • nono77
          • May 2009
          I talk about logfile (/var/adm/messages) solarisOS, access several time with item log[file,String] from several zabbix_agentd (zabbix agent active)on the same host.
          i just update from 1.6.4 to 1.6.5 agent+server and it seem to be Ok now
          Thank's for your help
