Web monitoring over Zabbix Proxy
  • emerzon
    • Apr 2008
    • 21
    I am trying to setup web monitoring to a host that is currently monitored by a Zabbix proxy agent. The Zabbix server doesn't have access to host being monitored, only the zabbix proxy does.
    However, when I setup a web monitoring for that hosts, it appears that Zabbix Server tries to send the http request to the host, instead of the zabbix proxy.
    Is there some way to "force" a web check to be executed from the proxy instead of the server?
    Both Server and Proxy are compiled with libCurl, version 1.6.4.
  • Alexei
    Founder, CEO
    • Sep 2004
    • 5654
    This will be supported in 1.8 only.
    Alexei Vladishev
    New York | Tokyo | Riga
    My Twitter
    • emerzon
      • Apr 2008
      • 21
      Ok, Thanks!
      • fredo2906
        • Jan 2011
        • 14
        I am using the version 1.8, but sounds like it is also sent from the server itself.
        • gelowe
          • Jun 2008
          • 30
          When?????
          When will this be supported?
          having to setup a multi-node configuration just to get web checks going from different ip endpoints seems a HUGE waste.
          • cferraro
            • Jun 2011
            • 16
            update on web monitoring via Zabbix proxy?
            Any update on when this feature will be available in a release?
            My workaround of having VPN tunnels between my cloud Zabbix server and target networks is not scalable.
            • w3bservice
              • Jun 2011
              I'm also interested.
              I'm testing with 1.9.5 and still does not work.
              • cferraro
                • Jun 2011
                • 16
                Still unresolved.
                Others interested in this functionality are encouraged to vote up the feature request.
