Actions based on SNMP traps do not recognize Host Group
  • anon
    • Jun 2009
    • 9
    I'm using Zabbix 1.6.5. I have SNMP traps set up with no issues, the host is logging the trap data. However, I am trying to set up an action to send an email when:
    Trigger Severity >= Information AND
    Host template = SNMP Traps AND
    Host Group = foo
    Everything works great and the desired email is sent until I add the "Host group" condition. Once this is added, I get "No actions found" in the event detail.
    I've ensured that the host itself is a member of Host Group "foo". If it matters, the host is a member of two total Host Groups.
    Can anyone help?
    TIA
  • richlv
    • Oct 2005
    • 3112
    sounds like the same problem as http://www.zabbix.com/forum/showthread.php?t=13121
    • anon
      • Jun 2009
      • 9
      That's this thread.
      But, actually, I just figured the issue out. The user to whom the trap should have been emailed to was put in the "Zabbix Super Admin" group and the traps are emailed properly now.
      The user was in group "Zabbix User" before. I suspect the user didn't have explicit permission to the Host Group in question, but I didn't check beforehand...
