zabbix on redhat 5
  • safaa
    • Jun 2009
    • 43
    zabbix on redhat 5
    Hello everybody ,
    I want to setup zabbix on redhat 5 (It's an obligatory work) can someone tell me the steps that I must follow please,I'm new in linux in general,please help Thanks so much in advance.
  • tighep
    • Dec 2007
    • 124
    Follow the guide for CentOS, they are very similar.
    • safaa
      • Jun 2009
      • 43
      Cannot find a valid baseurl for repo: epel-testing :redhat 5
      HELLO everybody,
      I'm new in linux ,I setup redhat 5 and I want to install zabbix ,but the problem is when I write yum --enablerepo=epel-testing install zabbix zabbix-agent zabbix-web for instance ,I've got :
      Loading "installonlyn" plugin
      Loading "rhnplugin" plugin
      This system is not registered with RHN.
      RHN support will be disabled.
      Could not retrieve mirrorlist http://mirrors.fedoraproject.org/mir...pel5&arch=i386 error was
      [Errno 4] IOError: <urlopen error (113, "Aucun chemin d'acc\xc3\xa8s pour atteindre l'h\xc3\xb4te cible")>
      Please help me ,I don't know what to do ,Thanks so much in advance.
      • xaeth
        • Nov 2004
        • 67
        Fedora's mirrors were having some issues recently. I'm not sure if its been resolved as of yet, but I thought it had been.
        Although I just looked a bit closer, and I don't see a zabbix rpm in epel-testing, just in epel, so I wouldn't bother trying to troubleshoot epel-testing. Just make epel work.
        One thing to keep in mind is that EPEL only supported 1.4.6 of Zabbix. The Fedora10+ Zabbix 1.6 source RPM rebuilds fine on RHEL5 as long as you do have certain EPEL provided packages installed.
        • Haka Code
          • Sep 2022
          Hi everyone.
          I need help.
          I need to install the agent ( zabbix-agent-5.0.25-1.el5.x86_64.rpm) in one machine with RHEL 5. When i run the comand "/sbin/service zabbix-agent status" the return is: "zabbix_agentd is stopped" when i start with comand "/sbin/service zabbix-agent start" the return is "Starting Zabbix agent [OK]" .So when i check with status the service still stopped. In this moment i can´t change the RHEL.​
          • tim.mooney
            • Dec 2012
            • 1435
            Originally posted by Haka Code
            So when i check with status the service still stopped.​
            Look in the log file for the agent (probably /var/log/zabbix/zabbix_agentd.log) to see if there are any messages there about why it isn't starting.
