hopefully this will be the last time i have to do this. When the zabbix server trys to start up, the following is in the zabbix_server.log file. I am not familiar enough with Mysql and zabbix interaction on how to attempt this. The zabbix database is built (as per the instrutions again). Sql server is running.
15393:20090831:142459 Starting zabbix_server. ZABBIX 1.6.5 (revision 7442).
15393:20090831:142459 **** Enabled features ****
15393:20090831:142459 SNMP monitoring: NO
15393:20090831:142459 WEB monitoring: YES
15393:20090831:142459 Jabber notifications: NO
15393:20090831:142459 ODBC: NO
15393:20090831:142459 IPv6 support: NO
15393:20090831:142459 **************************
15393:20090831:142459 [Z3001] Connection to database 'zabbix' failed: [2002] Can't connect to local MySQL server through socket '/tmp/mysql.sock' (2)
