i' using a zabbix server (about 70 hosts, fast fibrechannel mysql backend) with a zabbix proxy. the proxy collects data from routers(about 40 hosts) via snmp v2 and has a sqlite3 backend.
since i updated the zabbix server,proxy and frontend version from 1.6.4 to 1.6.6, i have some crazy problems.
1. Proxy data
the data which been received from the proxy server have a wrong timestamp.
the difference between the effective time and the timestamp grow bigger, and than it stops completly. i get a flow of data for about 1-2 hours, than it stops for about 1-2 hours and than it start again.the servers have exactly the same time. the servers are not at their performance limit.
i deleted the whole sqlite3 database at the proxy and recreated it, without results. i don't get any errors with advanced logging.
you have any idea?
2. Items
some items which worked the whole time get now a ZBX_NOTSUPPORTED (especially perfcounters). i tested it with agent 1.6.(4,5,6).
i'm thankful for any solution statement...
greets
1. Proxy data
you have any idea?
2. Items
greets
