Wildly inaccurage disk size reporting on FreeBSD
  • boysdontcry
    • Sep 2009
    I'm seeing an issue with disk size reporting on FreeBSD 7.2.
    Here are the sizes and usage as reported by df:
    Filesystem Size Used Avail Capacity Mounted on
    /dev/ad0s1a 248M 87M 141M 38% /
    devfs 1.0K 1.0K 0B 100% /dev
    /dev/ad0s1g 989M 480M 430M 53% /home
    /dev/ad0s1e 97M 3.3M 86M 4% /tmp
    /dev/ad0s1f 3.9G 3.2G 402M 89% /usr
    /dev/ad0s1d 989M 324M 587M 36% /var
    /dev/concat/data 192G 144G 33G 81% /data
    devfs 1.0K 1.0K 0B 100% /var/named/dev
    However, zabbix is saying that, for example, my /data partition is 48.07 TB, my / partition is 160.94 GB, and my /home partition is 509.6 GB.
    Any ideas as to what the issue is? Is this a known problem? I'm using Zabbix 1.6.5.
  • bweisz
    • Jun 2007
    I believe the disk sizes include a multiplier of 1024. If you remove the multiplier I think you will find the sizes as expected.
    • boysdontcry
      • Sep 2009
      Hrm. OK. I used the FreeBSD template that came with Zabbix. Is there a problem with it? I'm not sure where to fix this.
      • bweisz
        • Jun 2007
        Apparently the FreeBSD template has the multiplier configured - not sure why. You should be able to simply edit the template and remove the multiplier value.
        Its been a while since my last install but I do remember having to remove it in the template.
        • boysdontcry
          • Sep 2009
          Thanks. That did the trick. Hopefully they'll fix the template for the next release!
