Email notification does not works (1.6.6 w/ screenshots)
  • MikeAT
    • Oct 2009
    [SOLVED thanks to richlv]
    I've set up triggers for templates and hosts and define exaclty one Action which doesn't contains any condition (so always will be triggered if any trigger change its status).
    Triggers are working fine (screen1), when I watch History of Events, every rows contain - (dash) in Actions column (screen2) [cdre.py twice in list because first trigger link to host and another to template]. You can see (screen3) my Action definiton. SMTP setup is correct, Host: localhost, HELO: localhost, From address is a valid email, and smtpd is listening on 127.0.0.1:25 (any other application can send email)
    Have you got any idea what is wrong? I'm using Zabbix 1.6.6 with static linking on Ubuntu 6.06 i386
    Many thanks,
    Mike
    screen1:
    screen2:
    screen3:
  • richlv
    • Oct 2005
    • 3112
    and does group unix administrators have at least read access to the host that generates the event ?
    • MikeAT
      • Oct 2009
      [solved]
      Hi richlv,
      Ahh you're won! Administration -> Users -> User Groups (in select) -> 'UNIX administrators' -> Add rights
      I'm a newbie thanks your advice!
      Mike
