Zapcat trapper issues - esp from Java web apps.
  • vkarai
    • Nov 2009
    I have enjoyed using Zapcat with Zabbix. The standard Tomcat export from Zapcat and import from Zabbix works well and I can actually see the MBean attributes in Zabbix for all the MBean attributes I set up for the Tomcat host that gets created for you during the import process.
    I have also tried the Zapcat Trapper and it works great from a command line Java program. I can pick up MBean attributes as well other key/value pairs that you wish to send. However, I have had trouble using the Trapper from a web application. I built the application using Maven and deployed the generated WAR to Tomcat 6. I built the code with Java 6. The code always dies around here (outlined in red):
    public ZabbixTrapper(final String zabbixServer, final String host) throws UnknownHostException
    final String server = System.getProperty(SERVER_PROPERTY, zabbixServer);
    final String serverPort = System.getProperty(PORT_PROPERTY, Integer
    .toString(DEFAULT_PORT));
    final String serverHost = System.getProperty(HOST_PROPERTY, host);
    sender = new Sender(queue, InetAddress.getByName(server), Integer
    .parseInt(serverPort), serverHost);
    sender.start();
    Do you have any ideas as to how I can get the Trapper working in a web application? It is a very, very simple proof-of-concept web application. As I mentioned above, I've got this working in a regular command-line Java program running from IntelliJ IDEA. From this command-line program I have no problem pushing traps to Zabbix. I see these values in Zabbix soon after. I'm wondering whether the fact that Zapcat creates dmon threads causes problems in a managed (Tomcat) environment?
    The servlet code is simple and is shown hereunder. Bear in mind that this is only a proof-of-concept. I just need to show that the Trapper works in a managed environment:
    package com.real.research;
    import java.io.IOException;
    import java.io.PrintWriter;
    import java.net.UnknownHostException;
    import java.util.Date;
    import java.util.concurrent.TimeUnit;
    import javax.servlet.ServletException;
    import javax.servlet.http.HttpServlet;
    import javax.servlet.http.HttpServletRequest;
    import javax.servlet.http.HttpServletResponse;
    import org.kjkoster.zapcat.Trapper;
    import org.kjkoster.zapcat.zabbix.ZabbixTrapper;
    * ${NAME}
    * @author Viraf Karai
    public class Viraf extends HttpServlet {
    private static final String IP_ADS_TO_MONITOR = "172.21.121.249"; // "172.27.128.98"; //"192.168.0.150";
    private static final String HOST_TO_MONITOR = "SEAD2vkarai"; // mark-app01.dev.real.com"; //""mac.kjkoster.org";
    @Override
    public void init() {
    sendZabbixTrap();
    @Override
    protected void doPost(HttpServletRequest request, HttpServletResponse response) throws ServletException, IOException {
    @Override
    protected void doGet(HttpServletRequest request, HttpServletResponse response) throws ServletException, IOException {
    response.setContentType("text/html");
    final PrintWriter out = response.getWriter();
    out.println("<html>");
    out.println("<head>");
    out.println("<title>Hola</title>");
    out.println("</head>");
    out.println("<body bgcolor=\"white\">");
    out.println(String.format("<h1>Trapper message was sent to Zabbix at: %s</h1>", new Date().toString()));
    out.println("</body>");
    out.println("</html>");
    out.flush();
    for (int i = 0; i < 20; ++i) {
    sendZabbixTrap();
    try {
    Thread.sleep(3000L);
    catch(InterruptedException ie) {
    private void sendZabbixTrap() {
    Trapper trapper = null;
    try {
    trapper = new ZabbixTrapper(IP_ADS_TO_MONITOR, HOST_TO_MONITOR);
    final long currTime = System.currentTimeMillis();
    trapper.send("java.version", System.getProperty("java.version") + "_" + currTime);
    trapper.send("java.loaded.classcount", "java.lang:type=ClassLoading", "LoadedClassCount");
    trapper.send("viraf.networth", currTime);
    /*trapper.send("free.physical.mem", "java.lang:type=OperatingSystem", "FreePhysicalMemorySize");
    trapper.send("compiler.time", "java.lang:type=Compilation", "TotalCompilationTime");*/
    /* trapper.every(30, TimeUnit.SECONDS, "free.physical.mem", "java.lang:type=OperatingSystem", "FreePhysicalMemorySize");
    trapper.every(30, TimeUnit.SECONDS, "compiler.time", "java.lang:type=Compilation", "TotalCompilationTime");
    // simulate lots of important work being done
    Thread.sleep(Long.MAX_VALUE);*/
    catch (Exception e) {
    e.printStackTrace();
    /* catch (InterruptedException e) {
    e.printStackTrace(); //To change body of catch statement use File | Settings | File Templates.
    finally {
    if (trapper != null) {
    trapper.stop();
  • brettcave
    • Nov 2009
    There seems to be a bug with some environments with the Base64.encode function, which comes from a third party library (Ostermillerutils).
    have just submitted an internal implementation of Base64 encoding function to zapcat-1.3-beta now - check out SVN for the update.
    https://zapcat.svn.sourceforge.net/s...r/zapcat/util/ has the Base64 class, and then update the import found in the org.kjkoster.zapcat.zabbix.Sender class
    let me know if this resolves your problem.
