Hello good day I have a problem with icmppingsec ...
In the version of zabbix 1.8
my item is configured the following way:
Description: Ping response time
Type: Simple check
Key: icmppingsec
Type of information: Numeric (float)
Units: s
Use multiplier: Do not use
Store value: As is
This threw me wrong data .. ie increases me much data in ms ... as may be .40, 5.48, 11.71 and other higher values this is not normal because in the version 1.6.6 the values obtained were correct for this version ...
Try to also do this:
configure the item as follows:
Description: ICMP ping ms
Type: Simple check
Key: icmppingsec
Use multiplier: Custom multiplier
Custom multiplier: 1000
Having to change the multiplier of staff for 1000 because the fping responds in milliseconds and icmppingsec as the name says it responds in seconds, so precisam multiply by 1000, to receive the correct value of the graphics ... but this does not work ... This worked perfect for me vercion 1.6.6 ...
Type: Simple check
Key: icmppingsec
Units: s
Store value: As is
Type: Simple check
Key: icmppingsec
