Zabbix GUI - pre-1.8-9055
  • ufocek
    • Aug 2006
    • 161
    There's running zabbix server and agents version pre-1.8-9021, GUI pre-1.8-8858, with the version GUI with pre-1.8-9021 or the newest there are shown strange things on the map. Example is shown on attached screens of the same server, where one of the screen is OK and where is shown strange things.
    noc-db - 2 problems / 29 Unknow -> GUI pre-1.8-9055
    noc-db - 2 problems -> GUI pre-1.8-8858
  • richlv
    • Oct 2005
    • 3112
    that means 29 triggers for the host are in an unknown state - figure out why, fix the cause (or disable them )
    • brian
      • Dec 2009
      • 45
      And because of the above the device goes to "Unknown" state on the map.
      (trunk rev. 9092)
      • richlv
        • Oct 2005
        • 3112
        what do you mean ? status should not change, unless _all_ triggers are in an unknown state. in which case it really is quite... unknown
        • brian
          • Dec 2009
          • 45
          I use different icons for different status, and because of the problem, the icon changes to unknown.
          The device itself is working, it only has some items, which are not available.
          See attached image!
          • richlv
            • Oct 2005
            • 3112
            ah, but that's not element status, but trigger hilighting.
            • brian
              • Dec 2009
              • 45
              sorry, i used the wrong term.
              • richlv
                • Oct 2005
                • 3112
                i believe it's in line with hilighting when triggers fire. so your options are to solve the issue, or disable hilighting for the map.
                • brian
                  • Dec 2009
                  • 45
                  OK, I will try.
                  If the problem is in my config, then why does the map shows well with released version 1.8?
                  • ufocek
                    • Aug 2006
                    • 161
                    I do not see any triggers with unknow state, now I download the latest version from trunk but problem still exist.
                    • richlv
                      • Oct 2005
                      • 3112
                      released 1.8 had some bugs regarding the maps
                      • richlv
                        • Oct 2005
                        • 3112
                        what exactly is the problem at this point ?
                        you see unknown triggers in the map, but not in the trigger list ? where did you look for them ? i'd suggest monitoring -> triggers, selecting the host and choosing "show all"
                        • gospodin.horoshiy
                          • Sep 2008
                          • 272
                          Ohhhh ,
                          Is there anyway to disable this new feature? Maybe comment something out... The way I use templates, there are always some triggers in UNKNOWN state....
                          Zbx 2.0.4 on Debian and MYSQL5 on Ubuntu Server 64bit 8.04,
                          200+ Win Agents, 50+ Linux Agents, 150+ Network Devices
                          • richlv
                            • Oct 2005
                            • 3112
                            as noted, you can disable icon hilighting on the map level. you will still see unknown trigger count, but that should be much less distracting
                            • gospodin.horoshiy
                              • Sep 2008
                              • 272
                              #15
                              I'm more worried about Unknown trigger count than icon highlighting, actually...
