Zabbix GUI - pre-1.8-9055
  • imarinkovic
    • Nov 2009
    • 20
    #16
    Please, check http://www.zabbix.com/forum/showthread.php?t=15327
    • brian
      • Dec 2009
      • 45
      #17
      My problem is that the triggers showing up as "UNKNOWN" are default triggers from SNMPv2 device template, which should work out of the box. Data for these triggers are collected normally.
      Example:
      Item: ifInOctets4 (from template)
      Trigger:
      {Template_Routers_Drayteq_Vigor_2200E:ifInOctets4. delta(0)}>150000
      Latest data:
      Description Last check Last value Change
      ifInOctets4 11 Jan 2010 22:42:36 1578214700 +10040
      This trigger stays in unknown status.
      What am I doing wrong?
      • exkg
        • Mar 2007
        • 718
        #18
        I need say that will be good if (ate least) we get a option (checkbox?!?!?) to choose if we want view this 'UNKNOWN' triggers or not.
        We have used a lot of maps with custom images ... afeter this new feature our maps/screens become very ugly.
        []s,
        Luciano
        Luciano Alves
        www.zabbix.com
        Brazil | México | Argentina | Colômbia | Chile
        Zabbix Performance Tuning
        • exkg
          • Mar 2007
          • 718
          #19
          So ... to ZABBIX TRAPPER itens we'll get UNKNOWN till ZABBIX receive one value ... its a bad thing. We dint expect have UNKNOWN in this case.
          A sugestion is to have a new area (in admn tab) 'Unknow triggers and unsupported itens' ... so admins will can see this erros.
          []s,
          Luciano
          Luciano Alves
          www.zabbix.com
          • exkg
            • Mar 2007
            • 718
            #20
            Aly ?
            Some way/plan to disable this view in maps ?
            []s,
            Luciano
            Luciano Alves
            www.zabbix.com
            • richlv
              • Oct 2005
              • 3112
              #21
              there's no short-term plan for changes to the maps, however in 1.8 it should be much easier to find unsupported items - in the new item filter just set it to filter for all hostgroups and hosts and show items in unsupported state
              • DeDA
                • Mar 2011
                Any news of plans?
