Hi!
I have 1 Zabbix Server in headquarters and 10 Zabbix Proxies in branch offices across my country. I want to use these proxies for monitoring VPNs state between branch offices and individual labs connected to these offices. There will be in total over 200 various vpn connections.
I set up host named "City1-Lab11-VPN", monitored by City1-Proxy, then I added items: "simple check icmpping" and "simple check icmppingsec" but it doesn't work, I got item values=0. This method works only in two cities, in all others not. Strange. I have the same zabbix version installed everywhere (1,8).
I logged onto City1-Proxy, su - zabbix, ping and fping works and returns correct values.
As a result I have dozen of alerts about unavailable vpn connections but in fact they are ok.
So my question is: how to monitor vpn connection using zabbix-proxy instead icmpping? Or: Why this method is working with one proxy and not with others? Configurations are the same, installed using the same install script...
Thanks,
Skygge
Thanks,
Skygge
