PingerFrequency? icmpping and tick woes.
  • azilber
    • Apr 2005
    • 33
    I'm using 1.1alpha10. icmpping and tick have never returned any values. Why is this? They are both configured as simple checks. I noticed the docs speciy PingerFrequency, but where is this specified? anyone have examples of this working?
  • James Wells
    • Jun 2005
    • 664
    Greetings,
    Right off the bat, I suspect that you don't have fping installed, or if you do that it is not executable by the Zabbix server user.
    Unofficial Zabbix Developer
    • azilber
      • Apr 2005
      • 33
      Ok that has solved half my problem. :-)
      Originally posted by James Wells
      Greetings,
      Thank you!
      I had changed fping to just call ping. My assumption that they are "similar enough" was false. I've also found PingerFrequency in the conf file which I changed and restarted zabbix_server. I now have data for ping checks after installing fping and changing the conf file.
      But, Tick is still not.. ticking....
      • azilber
        • Apr 2005
        • 33
        tick...?
        Checking the manual.. I cannot find tick. Was this removed? I swear I got it out of the Zabbix manual.. but it's not in there now... I will switch to ping instead.
        Originally posted by azilber
        Thank you!
        • James Wells
          • Jun 2005
          • 664
          Hmmm, not familiar with that one. Can you point me to the Docs where you saw this referenced please?
