how to add ldap users
  • ransu75
    • Jun 2010
    After configuring the ldap authentication on Zabbix, I got an LDAP Login successful, however I was wondering how to add my ldap users now ? I mean can we list the ldap users and pick-up them ?
    I haven't seen anything about this in the manual.
    Thanks in advance,
    Ransu
  • MrKen
    • Oct 2008
    • 652
    You need to manually add the users to Zabbix gui. Administration -> Users -> Create User
    The user name must be the same as configured in your ldap server, no need to add password when creating the user. When the user logs in, his/her password is checked with the ldap server.
    HTH
    MrKen
    • ransu75
      • Jun 2010
      Thanks it works!
      • Bruno Santinato
        • Mar 2020
        I installed Zabbix Server 4.2.8 in a virtual machine to learn about Zabbix Monitoring tool.
        So, i am configure the Authentication LDAP Settings with success.
        I am using FreeIPA Server to centralize my users, when i create LDAP User in Zabbix Web Interface creates with success, but cannot login with LDAP Password (no other password too).
        Can someone help me ?
        • Alistair0866
          Alistair0866 commented
          Hi your Base DN is looking at admin only change so it starts at cn=users and usually Samaccountname ist best to use as search attribute, at the bottom press test button to see if your config works!
      • fwalk
        • May 2021
        Finally someone who posted what it should look like when setup. Also someone who was able to not only make Bruno's work but mine also. I got rid of the ldap://server-name.com and just put in the IP like you have above and my two day venture was over. Cudos to you Alistair0866 you are the man. Thank you so much.
