host.status problem in 1.8.3
  • ad@kbc-clearing.com
    • Sep 2005
    • 77
    Hi all
    We just upgraded from 1.8.2 to 1.8.3.
    Everything works find except for host.status.
    In 1.8.2 host.status=0 when host is reachable, host.status=2 when host is not reachable. That is what you would expect.
    However, in 1.8.3 host.status is messed up; some hosts (but not all) got status 2 while reachable.
    The hosts are all windows 2003 servers with different zabbix agent versions installed. But same problem occurs on winxp and linux servers.
    Anyone experienced similar problems ?
  • jay
    • Dec 2009
    • 11
    I have the same problem with 1.8 agent and server. I just upgrade the server in 1.8.3 and for the moment, the agent will stay in 1.8. I will see if this problem persist.
    For the moment I use the ping item to monitor host availibility.
    Regards
    • nima0102
      • May 2010
      • 106
      Hi
      After upgrade server to 1.8.3, I have same problem with few hosts!Is it need to update agents to 1.8.3?
      Thanks in advance
      • asaveljevs
        Zabbix developer
        • Feb 2010
        • 36
        You can use the method described in https://support.zabbix.com/browse/ZBX-2980 as a workaround.
        • nima0102
          • May 2010
          • 106
          Thanks for your attention.
          Our agents are on linux,Do I have to upgrade to 1.8.3?of course I have updated server to 1.8.3.
          Thanks for more information.
          • asaveljevs
            Zabbix developer
            • Feb 2010
            • 36
            No, it is not necessary to upgrade agents to 1.8.3 - item "status" works entirely on the server side and does not depend on the agent version.
