zabbix server start problem, solaris+oracle
  • DmitryGFP
    • Nov 2010
    Dear all,
    Seems I've read all the posts concerning the start of zabbix server, but still I can't find the answer.
    My configuration: Solaris 10 + Oracle 10.2.0.4 + Zabbix 1.8.2.
    I made changes to the files
    /zabbix-1.8.2/src/libs/zbxdb/db.c and
    /zabbix-1.8.2/frontends/php/include/db.inc.php
    as stated here: https://support.zabbix.com/browse/ZBXNEXT-435
    in order to use the tnsnames method to connect to Oracle instead of easy connect //hostname/database.
    My /etc/zabbix/zabbix_server.conf contains:
    DBName=ZABBIX
    DBUser, DBPassword = zabbix
    DBSocket=/var/tmp/.oracle/s#344.1 (which is zabbix listener socket)
    DBPort=1526
    other parameters are commented
    The output of zabbix_server.log runs:
    28578:20101124:111108.831 Starting Zabbix Server. Zabbix 1.8.2 (revision 11211).
    28578:20101124:111108.832 **** Enabled features ****
    28578:20101124:111108.832 SNMP monitoring: YES
    28578:20101124:111108.832 IPMI monitoring: NO
    28578:20101124:111108.832 WEB monitoring: YES
    28578:20101124:111108.832 Jabber notifications: NO
    28578:20101124:111108.832 ODBC: NO
    28578:20101124:111108.832 SSH2 support: NO
    28578:20101124:111108.832 IPv6 support: NO
    28578:20101124:111108.833 **************************
    28578:20101124:111109.015 [Z3001] Connection to database 'ZABBIX' failed: [-1]
    No more errors, no more traces. Oracle listener log contains nothing.
    If anybody has the experience in setting up Zabbix on Oracle + Solaris, could you please help me? I really don't know where to search further...
  • untergeek
    • Jun 2009
    • 512
    I once tried to run a Zabbix server on Solaris with an Oracle 10 backend.
    It FAILED. Miserably. For some reason, Oracle 10 is suspect. We were successful with Oracle 11.
    Next, we had to run a screwy connect string in order to connect. If you look through some of my former posts, you may find my solution.
    As a side note, Solaris, for all of its multi-threaded goodness is not a happy mix with Zabbix, especially with Oracle on the backend. Zabbix is written to take advantage of x86's very fast single threads. We used a high-end Sun server (a t5120 with 16G of RAM) and we still had horrible performance. This was with a required number of writes per second of only 250. In theory this shouldn't have even tickled a server with so many threads. However, as soon as we pushed over to an HP DL360 running RHEL our Zabbix performance improved over 10x. Our queue dropped to almost nothing.
    I can't emphasize enough the horrid performance we had running on Sun hardware. Solaris on x86 may be okay, but I have no frame of reference.
    Don't even get me started on the problems we have with the zabbix_agentd process on our busiest servers. That's actually in a different thread here. Suffice to say that the single-threaded nature of the code keeps us from being able to take full advantage of "Active Agent" data collection with Sun hardware.
    • DmitryGFP
      • Nov 2010
      Thanks, untergeek
      I think I'll rely on your larger experience.
      This configuration is an existing server so I was just hoping to make it up shedding hardly any blood...
      • idongyong_zabbix
        • Dec 2010
        Did you solved this problem?
        I met this problem just as you .
        i searched all the forums,but can't connet to oracle.
        3612:20110213:174514.659 Starting zabbix_server. Zabbix 1.8.1 (revision 9702).
        3612:20110213:174514.659 **** Enabled features ****
        3612:20110213:174514.659 SNMP monitoring: YES
        3612:20110213:174514.659 IPMI monitoring: NO
        3612:20110213:174514.659 WEB monitoring: YES
        3612:20110213:174514.659 Jabber notifications: NO
        3612:20110213:174514.659 ODBC: NO
        3612:20110213:174514.659 SSH2 support: NO
        3612:20110213:174514.659 IPv6 support: NO
        3612:20110213:174514.659 **************************
        3612:20110213:174514.661 [Z3001] Connection to database '//localhost:1521/monitor' failed: [-1]
        can you help me ? thank you.
        email:[email protected]
        • untergeek
          • Jun 2009
          • 512
          Zabbix 1.8 and Oracle 10 simply do not get along in my experience.
