I am installing zabbix 1.8
I have encountered this error
checking for curl_free... yes
checking for net-snmp-config... /usr/local/bin/net-snmp-config
checking for main in -lnetsnmp ... no
configure: error: Not found NET-SNMP library
while configuring...
i have installed net-snmp and libcurl using the tar balls available online.
what is the issue.
I am also using suse 9
if i do configure without net-snmp will i still be able to check process instances on a client machine using agents?
what are the uses of net-snmp?
what is the issue.
