Actions permissions
  • bernard
    • Oct 2008
    • 54
    Actions permissions
    As Zabbix Super Admin I see 43 actions. But Zabbix Admins can see only 2 actions (most recent it seems).
    I'm running server 1.8.3. (1.8.4 doesn't fix that as I saw in relaese notes).
    I have checked in Zabbix manual and book, and I understand that permissions related to Actions are not allowed by group, but by user type (User, Admin, Super Admin). Is that correct ?
    If Yes, why do I have this issue ?
    Many thanks for your help,
    Regards,
    Bernard
  • italux
    • Jul 2010
    • 21
    I had same issue, and I solved associating Zabbix Admin Users a User Group with permissions to read and write certain configs on certain host groups.
    • bernard
      • Oct 2008
      • 54
      Little bit better
      Thanks Italo,
      Before me colleague has 2 actions, after giving him read-write permissions on all hosts, he can see 3 actions.
      But... I have 43 actions
      Your tip doesn't work for me.
      Any other idea ?
      • ribbon
        • Feb 2011
        Have you solved the problem if so please give me more information on that because I am having a similar problem with it. It is not detecting all the action and also it does not work on the configuration correctly. Please do send some information on the matter and thanks.
        ______________
        website
        • bernard
          • Oct 2008
          • 54
          No news
          No news yet. I will open an incident next week.
          All actions work properly, but "Zabbix admin" users don't see all of them (and can not managed them).
          Regards,
          • richlv
            • Oct 2005
            • 3112
            zabbix admin only sees those actions where he is also member of same user groups as target users/usergroups in the operations of that action
            • bernard
              • Oct 2008
              • 54
              Thanks richlv,
              Your answer is clear, but I don't like it
              If I want my "Zabbix Admin" to be able to manage all actions, I need to promote them to "Zabbix Super Admin".
              Does Zabbix will change that in a future release ?
              Regards,
              • richlv
                • Oct 2005
                • 3112
                or that admin must be in all those usergroups. basically they should not be able to discover all other users & groups on a system just by going to action configuration.
                there are no short term plans to change this.
                • bernard
                  • Oct 2008
                  • 54
                  OK, it makes sense.
                  As a lazy admin I will promote the "Admin" to "Super Admin" instead of thinking about the design of groups.
                  Many thanks.
                  • sambhu.prakash
                    • Apr 2021
                    • 21
                    Hi ,
                    Try to clone the Super Admin role and have these settings enabled at least. The users now assigned to this role should be able to see the problem actions.
                    Thanks.
                      • 5004
                      Originally posted by sambhu.prakash
                      Hi ,
                      Thanks.
                      Ooh... necroposting.. resurrecting a 13 year old topic with an answer containing methods that were never around when the question was asked...
                      • sambhu.prakash
                        • Apr 2021
                        • 21
                        Yeah, I thought I should post it if someone is still struggling with setting that up. Pardon my negligence as a Junior member
