[Linux] Monitoring (active) open file descriptors
  • Mojah
    • Apr 2010
    • 60
    We can use the Zabbix agent to retrieve the max amount of open file descriptors, as defined by the kernel on a Linux system.
    Can we also use that zabbix agent (with the built-in options) to check how many open files they currently have? I seem to be missing it, or just completely looking over the options.
    Since we're managing a few hundred servers, I don't want to implement it on each system as a custom UserParameter in the Zabbix Config, but a standard Zabbix Agent check would be nice. :-)
    If not, I'll revert to a "lsof | wc -l" kind of solution, but prefer to keep that as a last resort.
    Regards,
    M.
  • Eracius
    • Apr 2011
    Hello Mojah,
    Did you find a way to monitor open files in Zabbix ?
    • Mojah
      • Apr 2010
      • 60
      Originally posted by Eracius
      Hello Mojah,
      From default Zabbix-options: no.
      But I'm just going to look at using UserParameter's in custom Zabbix Configs, as I would've thought at first (lsof | wc -l). Not pretty, but on a short-term, it'll have to do.
      • tzn
        • Apr 2011
        • 19
        Just use in UserParameter:
        sysctl -e -n fs.file-nr|cut -f1
        • Mojah
          • Apr 2010
          • 60
          That tells the maximum configured open files, not the actual amount. I was hoping to do it without UserParameter's, but with built-in parameters in the zabbix agent.
          • tzn
            • Apr 2011
            • 19
            I only have problems with taht indicator on OpenVZ servers, but it might bo related to resource management on containers.
            • rashid_47010
              • May 2011
              no graphs data under the dashboard
              I install the zabbix server on my laptop while accessing it through web gui
              and create some graphs but no data coming on that graphs.
              kindly help me to sort out this problem
              • tzn
                • Apr 2011
                • 19
                I'm affraid this has nothing to do with monitoring FDs. Please put you question in separate thread and provide some datails. Attach logs, configuration details, operating system version, zabbix version etc.
                You should be able to see at least data form zabbix server itself.
                • richlv
                  • Oct 2005
                  • 3112
                  That still does not seem to be available, created https://support.zabbix.com/browse/ZBXNEXT-5327 . Please vote on it if there's still interest in such a feature.
