Hi team,
I try to monitor hp proliant ml350 g6 servers using zabbix. hp insight manager is installed on all my windows 2008 r2 servers and seems working.
SNMP is configured with the good community : snmpstatus -v 2c -c public 10.205.211.11
[UDP: [10.205.211.11]:161->[0.0.0.0]]=>[Hardware: Intel64 Family 6 Model 26 Stepping 5 AT/AT COMPATIBLE - Software: Windows Version 6.1 (Build 7600 Multiprocessor Free)] Up: 0:37:15.06
Interfaces: 27, Recv/Trans packets: 15872091/2799515 | IP: 5073373/1068442
8 interfaces are down!
I can get some data from my servers but when i use the template HP Insight, there is some problem :
Zabbix server : /var/log/zabbix/zabbix_server.log
Is there anything special to set up ? or the mib changed with this version ?
I use the iLo 2 communication port to monitor the hosts.
Thanks in advance ...
2357:20110307:132739.607 Item [SERVTD1T_ILO2:HPcontrollerRollupStatus.1] error: SNMP error [(noSuchName) There is no such variable name in this MIB.] 2359:20110307:132740.616 Item [SERVTD1T_ILO2:HPcontrollerRollupStatus.2] error: SNMP error [(noSuchName) There is no such variable name in this MIB.] 2360:20110307:132741.614 Item [SERVTD1T_ILO2:HPenclosureRollupStatus0.1] error: SNMP error [(noSuchName) There is no such variable name in this MIB.] 2358:20110307:132742.611 Item [SERVTD1T_ILO2:HPenclosureRollupStatus0.2] error: SNMP error [(noSuchName) There is no such variable name in this MIB.] 2356:20110307:132743.611 Item [SERVTD1T_ILO2:HPenclosureRollupStatus1.1] error: SNMP error [(noSuchName) There is no such variable name in this MIB.] 2356:20110307:132744.616 Item [SERVTD1T_ILO2:HPenclosureRollupStatus1.2] error: SNMP error [(noSuchName) There is no such variable name in this MIB.]
