zabbix-server can't start
  • freshmanlemon
    • Aug 2011
    Hi.
    I have the next problem:
    OS: fedora 15
    DB: mysql
    Zabbix: 1.8.5
    OS is fresh, installed just for zabbix. when i try to start zabbix server, i see:
    [root@yfn-srv-f /]# service zabbix-server stop
    Stopping zabbix-server (via systemctl):                    [  OK  ]
    [root@yfn-srv-f /]# service zabbix-server start
    Starting zabbix-server (via systemctl):                    [  OK  ]
    [root@yfn-srv-f /]#
    But in zabbix_server.log:
    Debug level 4 (max)
    6602:20110815:021542.972 Starting Zabbix Server. Zabbix 1.8.5 (revision 19050).
      6602:20110815:021542.973 ****** Enabled features ******
      6602:20110815:021542.973 SNMP monitoring:           YES
      6602:20110815:021542.973 IPMI monitoring:           YES
      6602:20110815:021542.974 WEB monitoring:            YES
      6602:20110815:021542.974 Jabber notifications:      YES
      6602:20110815:021542.974 Ez Texting notifications:  YES
      6602:20110815:021542.974 ODBC:                      YES
      6602:20110815:021542.975 SSH2 support:              YES
      6602:20110815:021542.975 IPv6 support:              YES
      6602:20110815:021542.987 ******************************
      6602:20110815:021542.987 Connect to the database
      6602:20110815:021543.016 Query [txnlev:0] [SET NAMES utf8]
      6602:20110815:021543.017 Query [txnlev:0] [SET CHARACTER SET utf8]
      6602:20110815:021543.018 Query [txnlev:0] [select refresh_unsupported from config where 1=1 and configid between 000000000000000 and 099999999999999]
      6602:20110815:021543.020 In init_database_cache()
      6602:20110815:021543.020 In zbx_mem_required_size() size:8420916 chunks_num:4 descr:'history cache' param:'HistoryCacheSize'
      6602:20110815:021543.021 End of zbx_mem_required_size() size:8421263
      6602:20110815:021543.021 In zbx_mem_create() descr:'history cache' param:'HistoryCacheSize' size:8421263
      6602:20110815:021543.023 Cannot allocate shared memory of size 8421263 [Permission denied]
      6602:20110815:021543.023 cannot allocate shared memory for history cache
    In mysql:
    I have installed phpmyadmin, so there i set all privileges to user 'zabbix' to db 'zabbix.*'
    sory, i'm not good in mysql and dont know how to look it in console.
    So, i realy cant understed where is a trouble (( which kind of permission is denied and where.
    Please, help.
  • Colttt
    • Mar 2009
    • 878
    you must change the shmax in the kernel-config..
    look at this:
    http://dev.mysql.com/doc/refman/5.0/...e-support.html
    Debian-User
    Sorry for my bad english
    • freshmanlemon
      • Aug 2011
      I have read many forums, changing of SHMMAX solve problem when in log the next
      Can't allocate shared memory of size 29361092 [Cannot allocate memory]
      But in my case:
      The current value of shmmax in system is 33554432
      it is bigger then needed to zabbix I think.
      Anyway I have chenged it
      [root@yfn-srv-f proc]# cat /proc/sys/kernel/shmmax
      268435456
      the same result
      1721:20110815:131102.627 Cannot allocate shared memory of size 8421263 [Permission denied]
        1721:20110815:131102.627 cannot allocate shared memory for history cache
      I realy think i have a problem with privileges
      • Colttt
        • Mar 2009
        • 878
        ok.. ehm.. i think its a problem of SElinux.. disable that or reconfigure this..
        Debian-User
        • freshmanlemon
          • Aug 2011
          Yuuuhuuu! ))
          Shad0w, Thank you so much!
          Realy, it's SELinux.
          Right now I just disabeled it and zabbix-server started well! The next step is RTFM of SELinux.
          Thanks a lot one more time!
          • Colttt
            • Mar 2009
            • 878
            I like your name
            ok and why?
            Debian-User
